Latency In Playback mode
Posted: Sun Dec 26, 2004 4:11 pm
by Akai96
Is anyone experiencing sloppy timing in playback mode,Mainly Drums?
Re: Latency In Playback mode
Posted: Fri Feb 10, 2006 2:25 pm
by lore79
I have a lot of problem bacause my Mach5 has a really mad playback latency, can you help me?
Latencyproblems with mach5
Posted: Sat Feb 11, 2006 2:47 pm
by LePalm
I have the same problem! The greater buffersize, the greater latency.
I tried the exs24 in logic and the timing was perfect, at any buffersize,
as for other software instruments in performer (where I use Mach5).
Anyone experienced this and solved it?
found the cause
Posted: Sun Feb 12, 2006 3:01 am
by LePalm
I found the cause of playback latency in my case. When I bus out the diffrent drums on diffrent buses, the latency occures, it works perfectly when going through the main out! that's a drag though, what is the purpose of the ability to bus out the diffrent parts in M5 if a latency appears? Am I missing out something here?
Posted: Wed Feb 15, 2006 3:10 am
by 3over3
I've found a fairly consistent (say) 128 sample delay when I bounce things within Pro Tools. The solution is fairly simple, - as I'm using PTLE which doesn't have delay compensation (by the way, that's the reason why EXS is tight) I just pick the bounces up and drop them 128 samples (or whatever) earlier. But it is consistent as far as I can tell.
The word "sloppy" would indicate varying latency (like a drummer going in an out of time). Can I ask if anyone is experiencing this? This could be caused by samples not being trimmed exactly right (which happens - even in commercial libraries - and would be particularly noticable on short percussive sounds) or by MachFive's timing wandering in and out. I've not noticed MachFive's timing wandering - has anyone?
