Hello,
I just got an ultralite mk3 and started using it last night.
I tried to use the two XLR input with two microphones, but I ran into a problem:
I was not able to hear the two microphones simultaneously through my output monitors. I was able to see the two microphones were registering input looking at the small ultralite green screen. I made sure the 'I' was turned orange for both tracks but I could only hear one or the other, not the two.
Then I unplugged one of the microphones (XLR) and plugged in a guitar (1/4 plug) in the same input, leaving the other XLR mic connected, and I was able to hear the guitar and the microphone.
I think this is a configuration problem, but I am unsure where to begin. This is my first time using ultralite and I am not yet very familiar with it.
Please any insight, advice on how to approach this towards a solution would be great.
I hope someone can share some light.
Best,
anavagomez.
Connecting two microphones via XLR
Mac Notebook Pro/ OS Yosemite
Logic Pro X
UltraLite 10x14 FireWire Interface with MIDI
Logic Pro X
- daniel.sneed
Re: Connecting two microphones via XLR
You're welcome, but if you expect real help on this board, I think you should first of all list your setup.
Sequencer, computer, OS, interface, and the like.
You did not even mention your audio interface.
In the board user control panel, you may list your setup as a signature.
dAn Shakin' all over!
Thank you for the tip, Daniel. I have updated my signature listing my set up.
Here is the list:
Logic Pro X
AKG-P220
SM-57
Here is the list:
Logic Pro X
AKG-P220
SM-57
Logic Pro X
Logic Pro X
You aren't mentioning which mic is giving you the problem. One (the AKG) requires phantom power while the other doesn't.
Is this the issue? No idea.
The inputs and outputs need to line up. Normally, you output to a stereo track and pan R/L -- but you don't have to.
What does MOTU Audio Setup.all (Applications Folder) show? What does Audio MIDI Setup.app (Utilities Folder) show?
Because of the way that Logic assigns ins/outs, it isn't quite the same as Audio Express or Digital Performer. You can download Audio Express 4 from MOTU for free.
You may have to give MOTU Support a call.
Hi Mike,
Both microphones work. I cannot use both at the same time, that is I can not get them to record in their own track simultaneously. I wanted to record an acoustic guitar and use both microphones.
I can only hear one at a time. I will download the application you recommended and see if that gets me somewhere forward.
I also bought an XLR to 1/4 plug balanced adapter since the input jack works when using microphone and instrument.
Logic Pro X
Logic Pro X
