Crashing G4
Posted: Tue Jul 05, 2005 3:07 am
by dufftrio
I have a mirrored doors G4, dual 1 gig, w/ DP 4.52 and a PCI 424 to a 2408 mark II.
Having a lot of trouble crashing frequently. Is it possible that it is because the energy saver has been on?
Any other solutions?
Re: Crashing G4
Posted: Tue Jul 05, 2005 8:22 am
by wolfetho
You didn't mention if you're using Tiger or not? If so, I have a g4 dual 1.25 ghz w/ Tiger which was crashing alot with DP 4.52. I was also getting alot of Kernel Panics. The problem seems to be solved
by doing a clean install of Tiger. Originally I upgraded to Tiger doing an archive and install of the OS.Everything is much more stable after doing a clean install.
Tom
Re: Crashing G4
Posted: Tue Jul 05, 2005 8:32 am
by dufftrio
It was crashing with 10.3.8, and it was crashing after a complete clean install of 10.4.1.
Really suspecting the energy saver, and scren saver was the culprit. Has calmed down considerably after turnign them off.
Re: Crashing G4
Posted: Sat Aug 06, 2005 4:51 am
by folknbluzn
purchased a new 14" ibook with g4, 512mg, 1.42ghz and tiger 10.4.2. loads everything ok, even past work from my external HD, however, whenever i hit play or record, the audiodesk 2 software crashes?????????? any suggestions? I have downloaded 2 updates from motu
Re: Crashing G4
Posted: Sat Aug 06, 2005 6:15 am
by midiw
When did this start?
When does the crashing occurr?
This info may help give you some pointers/check this type of information/guidance.
Incdiently, are you doing the required system maintenance?
Re: Crashing G4
Posted: Sat Aug 06, 2005 8:08 am
by jonnyfive
I was recently having lots of instability problems. It seemed hard to track, I did alot of troubleshooting and as a last resort I sent my RAM back to the manufacturer. Everything is just peachy now. If you have gotten new RAM recently (even if it passes Hardware tests) I would suspect it. Besides most RAM chips have waranties, and for the price of shipping its worth a try.
As far as symptoms went, all my programs were affected, but mostly audio/graffic intensive ones. lots of "kernel protection failure, bad access exceptions". And just for the record, it seemed to get worse from 10.3.7 onward.
Worth a try.
Jonny
Re: Crashing G4
Posted: Sat Aug 06, 2005 8:21 am
by dufftrio
Thanks for the help folks.
The Mac tech scoped it out, and we found out there has been heat damage to the logic, and it is $800 to repair.
So I went out and bought a G5!
