Installation Failed on Yosemite!!!!
Posted: Wed Nov 26, 2014 8:30 pm
by donadi
Hello,
After using DP8 on my MacPro, I decided to install it on a brand new Macbook Pro with OS 10.10 on it. After downloading the DP 8.07 full setup file from Motu, the installations fails over and over.....!!!!
The Macbook Pro is brand new with a SSD drive, could the SSD cause the problem?? or is it Yosemite?
Anyone having this problem? I was searching online but couldn't find an answer.
Thank You
Dani
Re: Installation Failed on Yosemite!!!!
Posted: Wed Nov 26, 2014 8:43 pm
by mikehalloran
Probably not. Many of us have it installed on our SSDs
or is it Yosemite?
Nope
That's because, normally, there's no problem.
You need to walk us through your installation and the problem. Telling us it doesn't work isn't enough.
Posted: Wed Nov 26, 2014 8:46 pm
by MIDI Life Crisis
You might try putting the installer on a flash drive and installing from there. No reason. Just instinct.
Posted: Wed Nov 26, 2014 9:04 pm
by donadi
Mike:
Thanks, Just got the laptop yesterday, I want to use DP for a live gig so I decided to install it tonight.
The "Installation Failed" yellow triangle comes up right after I input my password.
I've repaired the permissions and also reset the Home Folder permissions (even though it's a brand new machine).
I downloaded the installation file twice (in case it was corrupted).
MLC:
Thank you, I've tried to install it from a flash drive without success.....
Re: Installation Failed on Yosemite!!!! FIXED
Posted: Thu Nov 27, 2014 6:57 am
by donadi
I fixed it.
MIDI Life Crisis, you were right, except it didn't work from a flash drive but it worked from an external USB drive……….hmmmmm!! strange!!!
Could be a permission issue in my Download folder….
Thank you for your help!
Dani
Posted: Thu Nov 27, 2014 7:33 am
by MIDI Life Crisis
I was just pissing in the wind. Sometimes that's the best way to put out the flames when your pants are on fire. Glad to help.
