Microlite issue
cdemby
Microlite issue
Post by cdemby »
Something happened to the Microlite unit as all 5 numbers are lit up. Not sure what the fix is on this, could use some help. thnx
Constance Demby
MacBook Pro HD -OS X
V 10.8.5
2.5GHz Intel Core i7
4 GB 1333 MHz DDR3
DP804
MOTU 828MKII / Micro Lite
Re: Microlite issue
Some detail on what you're doing, and what you've tried would help.
Tritonemusic
Re: Microlite issue
Post by Tritonemusic »
Did you try unplugging it and plugging it back in?
cdemby
Re: Microlite issue
Post by cdemby »
"Tritonemusic"] Did you try unplugging it and plugging it back in?
Yes, I knew that this was part of the fix ... I just pulled the plug on the microlite and there is sound, and I can compose... well, kind of because the speakers aren't working properly now. Need a techie to come to the studio and was hoping to find a pasadena based engineer to assist. Thanks...
Constance Demby
V 10.8.5
4 GB 1333 MHz DDR3
DP804
Re: Microlite issue
So the Micro Lite is working, just other stuff that isn't?
If not, the only other thing that I've seen make my Micro Lite do this is a MIDI loop.
