I set a default click pattern of eighth notes for a specific tempo range:
With auditioning turned on, the beat pattern plays correctly. But when I dismiss the Preferences window and hit PLAY in my sequence, DP still plays quarter-note clicks.
Here's the Control Panel:
(BTW: I tried adding a tempo event to the Conductor track, and switching the Tempo dropdown from "Tempo Slider" to "Conductor Track." No diff.)
Like the person in this thread from 2008, I was only able to get an eighth note click by manually inserting a Click Change event into the Conductor track. In other words, Defaults failed to work.
Now, I never use the Countoff Bars feature, but I tried an experiment. I deleted the Click Change event, and clicked the Countoff button to enable it. In the Countoff prefs window, "Click" is set to "Default for Meter." Now when I hit PLAY, I get a single bar countoff of eighth notes... and then the sequence starts playing, and DP still gives me quarter note clicks!
So Click Defaults only work in the Countoff? Huh??
DM
