PC88mx and the dreaded battery replacement
Posted: Sun Mar 09, 2014 2:16 pm
Hi,
After moving this past summer I finally setup my ANCIENT used PC88mx only to see the "battery low" message.
Many of you know what it's like to replace the fricken battery (no, I don't need directions, only sympathy). I did it just last year and was surprised to see the message as the keyboard was shut down in May and has been sitting unused and unplugged in the corner of my studio since June.
So, the question is: what actually happens if the battery dies? I'm using it ONLY as a dumb MIDI controller. I have no interest in presets, edits, or other functions, not even the internal sounds (the keyboard was twice repaired for faulty wiring that doest allow for stereo monitoring/play). If it's plugged in can I still use it play whatever sounds are triggered in either DP or Sibelius? Will it input with a drained or dead battery? I never thought of this, but figured it was worth an ask.
If I have to perform surgery I will, but it is a major PITA to take it apart and replace the battery. Anyone have any idea if I can avoid doing that but still use it?
Joel
Joel
