How do you create MARKERS?
- Primary DAW OS: Windows
The command to ADD MARKER is always greyed out, no matter which window I have up. The manual says nothing other than to select it. No can do. What am I missing here? Thx
- supersonic
Re: How do you create MARKERS?
I never had that. How about resetting DP's preferences just to make sure there is not a specific option you would have inadvertently chosen?
Music is movement in silence
Good idea. Will try that in the morning.
Thnx
Thnx
Re: How do you create MARKERS? Solved
Thanks, Super!
Problem solved! it was not in the general prefs, but it's a setting in the View menu. Turns Markers on and off and grays-out the option when turned off. I must have turned it off ages ago in my new template, because I have done a lot of sequences without having them available. Simple.
Gratias agimus tibi.
Pal
Pal
- supersonic
Cool
I add markers on the fly using Opt+M (I believe) Then I will tweak the measure where the marker sits and name it in the markers window.
I still suffer a moment of confusion when I see an Opt key reference. Well that's my excuse anyway...dpg4macman wrote:I add markers on the fly using Opt+M (I believe) Then I will tweak the measure where the marker sits and name it in the markers window.
DP8 - Windows 10 - i7 4ghz - 32 GB RAM - All Internal SSD harmonica with only one broken reed, lava lamp, cordless drill
- fullertime
I changed my "Add New Marker" command to just one key... literally the "1"... No option, no control just the "1" to add markers ... I use this ALL THE TIME and it saves tons of headache and is super fast. It's easy to do. IMHO One of DPs greatest features is the fact that you can create custom commands with ease. It's a brilliant feature that I love love love!
FULLER - Raleigh/Durham, NC
"You can't build a reputation on what you're going to do."
MacPro 3gHz 8-Core 16 GRam// OS 10.7.5 // ApogeePSX 100 // MOTU896 // MOTU Audio Express // DP8.01 //
