Lost Cue Mix FX Trim Functionality
cabster8
Post by cabster8 »
I own the original Ultralight. Since recent updates, I can't figure out how to get my trim knobs working in Cue Mix. When I attempt to adjust them with the mouse, the trim knobs will move and go to, let's say +5, then snap back to 0. Essentially not allowing me to use the trim feature to boost the signal. Any insight into why this is happening and the fix?
Additional Information: I have been adjusting the Trim in the Ultralight manually. As I adjust the trim manually for each channel, the knobs visably move in Cue Mix as I make the adjustment and stay at those new settings. So now, for example, I adjusted the trim to +5 manually for input 4 on the ultralight, it also shows +5 for input 4 in Cue Mix. However, if I try to ajust the trim to +9 for input 4 using the Cue Mix Interface, it simply goes back to +5 and will not adjust...strange...so basically, I can only adjust trim manually, not from the interface.
Best Regards,
Cabster
