Page 1 of 3
Logitech Control 3.9 + Mavericks = UGH!!! :(
Posted: Fri Nov 15, 2013 10:37 am
by James Steele
I'd recommend NOT installing Logictech Control Center 3.9 with Mavericks. I had some weird issues. The Dock would not appear unless I dragged the mouse to the bottom of the screen and CLICKED. Also if I clicked on a menu and then when the menu was stuck open, I dragged to the right, the menu would not close and open other menus. All sorts of weirdness.
I downgraded to Logitech Control Center 3.6. The 3.6 installer barked at me and told me it was not compatible with the newer version of OSX that I had installed (Mavericks). I went into the installer with "Show Package Contents" then drilled down to Contents/Resources/ and then double-clicked "Logitech Control Center.mpkg" and ran that installer just fine. Restarted... everything back to normal.
Re: Stay away from Logitech Control 3.9 with Mavericks!
Posted: Fri Nov 15, 2013 10:44 am
by James Steele
Great... mouse is working probably now, but I'm now missing my control panel in the System Prefs. Sigh.
Posted: Fri Nov 15, 2013 10:54 am
by MIDI Life Crisis
I stay away from ANY Logitech control panels.
Posted: Fri Nov 15, 2013 11:03 am
by James Steele
Yeah... well I'm in a quandary. I can't figure out which file is the actual preference pane that's supposed to show up in the System Prefs, but now it's missing. I did copy some Logitech Application Support files over from a backup I had, and now the scroll speed is set to where it was, but with the missing control panel, I can't adjust settings.
My next move is to reinstall 3.9 and if it's still hosed, run the uninstall and try to see if USB Overdrive is still working. Drat! I hope USB Overdrive supports all the functions of my particular mouse. I didn't last time I tried and that's why I had to abandon it. Now, because Logitech seems to have screwed up this version, I may have no choice. I can't get back to square one.
Posted: Fri Nov 15, 2013 11:17 am
by James Steele
Reinstalled Logic Control 3.9 and now it seems to be working again. Going to do a complete shutdown and boot from a cold start and see if it still works, but not until I do the Repair Permissions dance. That was weird. Going to amend my topic header to be less alarmist. :)
Posted: Fri Nov 15, 2013 11:18 am
by MIDI Life Crisis
Steer Mouse works in 10.9. Just sayin.... I know how much you like that. Not! But it works.
Posted: Fri Nov 15, 2013 11:25 am
by James Steele
MIDI Life Crisis wrote:Steer Mouse works in 10.9. Just sayin.... I know how much you like that. Not! But it works.
Oh... is that a 3rd party control panel? I'll give it a shot along with USB Overdrive if I haven't solved my issue with the Logitech control panel. Thanks!
Re: Possible Logitech Control 3.9 / Mavericks issue?
Posted: Fri Nov 15, 2013 11:34 am
by MIDI Life Crisis
I thought you knew about it and didn't like it? Maybe I was confusing it with Logic? Ha ha ha.
There's a special install thing with Logitech mice. You have to remove a Logitech component or something but it's an amazing mouse controller. Been using it for years. It replaces USB Overdrive for me.
Posted: Fri Nov 15, 2013 11:35 am
by James Steele
Well it looks like all is well again. Strange. I'm going to mark this resolved. So... I'm only about an hour and a half behind schedule on my routine today. Gotta just love computers. Could be worse. I could be running Windows. :) (I kid... I kid...)
Posted: Fri Nov 15, 2013 11:36 am
by James Steele
MIDI Life Crisis wrote:I thought you knew about it and didn't like it? Maybe I was confusing it with Logic? Ha ha ha.
No... didn't know about it. Thanks for hipping me to it. I just posted that I'm up and running again, so I may wait to try it. I'm in the cautious "if-it-ain't-broke-don't-fix-it" mode right now! :)
Posted: Fri Nov 15, 2013 11:45 am
by MIDI Life Crisis
It's only $20 and I don't think they have ever charged for an update. One of those tools I'd sorely miss if it went south.
Posted: Fri Nov 15, 2013 11:52 am
by James Steele
MIDI Life Crisis wrote:It's only $20 and I don't think they have ever charged for an update. One of those tools I'd sorely miss if it went south.
I'll try USB Overdrive again, then give that a shot. Clearly my issue isn't resolved. Just launched the Logitech control panel after repairing permissions and rebooting and got this:
Nice work, Logitech. On top of it my scroll button scrolls like molasses. Still haven't gotten any REAL work done this morning (soon to be afternoon)!
Posted: Fri Nov 15, 2013 12:01 pm
by MIDI Life Crisis
When I (temporarily) installed a new Logitech mouse recently (when mine was busted for a bit) the "Universal installer" or whatever they call that dongle, killed my solar Logitech keyboard receiver. I reset EVERYTHING but could not get it back. Eventually I returned the temporary "new" mouse with the old receiver (they were both universal receivers and it worked with the new mouse so no harm, no foul). But I have NEVER had any luck with Logitech software, which is odd because I think they make the best keyboards and mice.
There is, BTW, an uninstall app for the Logitech software which is hidden in:
User/Applications/Utilities/Logitech Unifying Software
The download was named lcc370.zip (or whatever version you are using, probably lcc390.zip in your case). Anyway, that well hidden app might be worth launching to see if there are any options to help you. I don't want to launch it on my system as I don't trust anything Logitech anymore when it comes to software.
Posted: Fri Nov 15, 2013 12:10 pm
by James Steele
Thanks... I ran the Uninstaller and purchased SteerMouse just now on your recommendation. I'll need to toy with the settings to get the ballistics back to where I feel comfortable again, but hopefully problem now solved. :( Updating header again! LOL THANK YOU for the recommendation! Tilt-wheel horizontal scroll works fine also. :) :dance:
Re: Logitech Control 3.9 + Mavericks = UGH!!! :(
Posted: Fri Nov 15, 2013 12:13 pm
by James Steele
Just looked at the clock. I began this odyssey over two hours ago... and NOW getting back to work. Ugh... thanks Logitech... not! LOL
