Apogee USB MiC and CoreDrive issue
massimosammi
Post by massimosammi »
Hi everyone,
I have connected a USB microphone (Apogee MiC) to my MacBook and I would like to use it as an input, while using as an output the Apogee Duet. The problem is that when I configure the hardware driver, I can't separate the input and the outputs on two different devices. Any suggestions on how to do that?
NazRat
Re: Apogee USB MiC and CoreDrive issue
Post by NazRat »
It's either ctrl-click or cmd-click that will allow you to select multiple devices in DP Hardware Setup. For other apps you can also create an aggregate device in AMS.
DP8.06 PT11.2.0 VEP 5.3.x
massimosammi
Thanks so much NazRat, it works great!! :)
