DP 8.04 Crashing on Mountain Lion
dmann200
Post by dmann200 »
I just upgraded everything in my system and now DP crashes every 5 minutes (literally)
The sequence that is currently crashing contains Kontakt 4, 2 instances of Omnisphere, and Altiverb 7.
My machine is Mac Pro Tower 5,1 with 4 cores (Hyperthreaded = 8) at 3.2 ghz.
16GB Ram
Solid state drive
MOTU 2408 Mark II audio interface
DP 8.04
OS X 10.8.4
Altiverb 7
Stylus (Latest)
Omnishere (Latest)
I have no idea why its crashing but it's making it very hard to work.
-D
Re: DP 8.04 Crashing on Mountain Lion
Have you updated all your drivers & repaired permissions? That is a very important step in stabilizing another wise unruly system.
David Polich
Post by David Polich »
Are you running DP 8.04 in 64-bit or 32-bit mode? Do you have the latest version of Altiverb 7? Kontakt 4 isn't 64-bit. Altiverb 7 comes up as an AU
in DP 8.04 in 64-bit mode, not MAS. These two plugs may be the culprit.
8.04 is solid here on my 2009 MacBook running OSX 10.8.4.
http://www.davepolich.com
Every once in awhile, DP 7.24 will crash on me in ML 10.8.4. I can almost predict which combination of plugs will do it (RX 2 and...) - it only happens when I am in a rush, too. I have only two more to finish then I am done with 7 unless I need to revisit a legacy project.
DP 8? Not ever, not once, hasn't happened yet.
