where did my uad go?
Posted: Thu Aug 08, 2013 6:16 pm
by stylemonster
just installed dp8, seems to have lost my uad plugins ... any quick tips?
Re: where did my uad go?
Posted: Thu Aug 08, 2013 8:10 pm
by James Steele
stylemonster wrote:just installed dp8, seems to have lost my uad plugins ... any quick tips?
DP8 will launch as 64-bit by default.
Find the DP8 app in the Finder and Get Info. Check the box to run in 32-bit mode. See if your UAD plugs are back.
You can also update to newest version of UAD plug-ins which are 64-bit compatible and then it won't matter (at least for the UAD plug-ins) if DP8 is running in 64-bit or 32-bit.
Posted: Fri Aug 09, 2013 12:20 am
by HCMarkus
Our webmaster an host has got it right. Update UAD (as long as you are using a UAD2 card) and you will be loving 64 bit operation.
Posted: Fri Aug 16, 2013 12:33 pm
by stylemonster
thanks guys - that did the trick (updated to 64 bit uad drivers / code). Don't know if its my imagination, but some of my mixes sound different too. one adjective might be 'effortless'. I guess that's 384 dB of dynamic range at work.
Posted: Fri Aug 16, 2013 12:43 pm
by James Steele
stylemonster wrote:thanks guys - that did the trick (updated to 64 bit uad drivers / code). Don't know if its my imagination, but some of my mixes sound different too. one adjective might be 'effortless'. I guess that's 384 dB of dynamic range at work.
Not exactly. 64-bit applies to memory addressing, not the audio. :)
