Lexicon Alpha don't work- RESOLVED
Posted: Fri May 03, 2013 3:14 am
by knoob
Hi
I've just installed DP8 demo but can't get my Lexicon Alpha interface to work. DP recognize it but i get no sound using the Lexicon Asio drivers. If I switch to Asio4all drivers i get sound but with poor performance. I'm sure it's DP "fault" because in Cubase 7 and other daws everything runs fine.
Re: Lexicon Alpha don't work
Posted: Fri May 03, 2013 5:45 am
by NazRat
Not familiar with your particular interface, but try moving your mains output pair to the top of the bundles window. That sets the default pair/audition/preview.
Posted: Fri May 03, 2013 7:11 am
by Radiogal
Same problem here with the Lexicon Omega. I have sent a notification about this straight to MOTU.
"I´m having big problems with the Lexicon Omega.(ASIO)
Latest Lexicon audio driver 2.7 (for W7) installed. (32 and 64 bit compatible).
DP loses the connection with it all the time. In both the 64 bit and 32 bit DP version. DP stops responding on transport/PLAY. DP stops working and the Hardware options are totally greyed out.
I have to force quit DP all the time and it´s useless. Very strange and it´s useless with this ASIO interface.
I read some other having similar problems with other audio interfaces so I thought I let you know.
The Windows internal audio driver seems to work fine AFAIK."
Posted: Fri May 03, 2013 4:07 pm
by knoob
Sometimes I can get Lexicon Alpha to work by changing the DP session samplerate from 41kHz to 48kHz and then on Lexicon settings to 48kHz and then, again on DP session (main screen), to 41kHz again. Sometimes it does not work. It's illogical...but once you get it to work it stays stable until you restart DP...then you have to do it again. So odd!
Posted: Mon May 13, 2013 3:30 pm
by knoob
Now, in ver 8.03 it seems to work perfectly.
Re: Lexicon Alpha don't work- RESOLVED
Posted: Tue May 14, 2013 2:02 am
by Radiogal
Same experience here. DP 8.03 fixed the ASIO problems! Thanks MOTU!
