I've only been using DP8 for a moth or so and have done several recording projects.
Haven't changed a thing but now, when I try to select an Input for a MIDI track, nothing happens - no drop down menu appears!
Using a MOTU 8 Pre to a Roland TD20 Drum Module.
Also, patch changes in previous DP8 projects are working work but not in my new project.
All MIDI Mapping, routing, bundles, cables etc seem to be correct and havent been changed.
Any thoughts??
MIDI Track Inputs Not appearing!
DP11, MacBook Pro 12.0, 16 Gig Ram, Motu 828MKll FW, 8Pre USB, 2 x 8Pre FW, Motu Micro Lite,
Lexicon, Yamaha, Mackie, dbx, Roland TD20 etc, etc.......
http://www.groovewerx.com www.oneuglycowboy.com
- FMiguelez
Re: MIDI Track Inputs Not appearing!
Have you checked your OS Audio/MIDI setup? What does it look like?
this sounds 100% normal...DP grabs all MIDI inputs automatically unless you turn on Multi record (from studio menu)
