New to MachFive3 - some thoughts / questions
Posted: Sun Feb 03, 2013 8:55 am
Hey everybody! Firstly i just want to say that i've only been using MachFive3 a couple of weeks - but so far i am blown away by the software, it's awesome - much superior to Kontakt and anything else. The synth side of it is mind-blowing too - a nice surprise. I can see MachFive3 becoming my go-to synth for sound programming! So many possibilities and features , yet under an attractive interface. Love the onboard sounds too.
It's not all good though… infact at the moment i am reluctant to use it in 'real' projects because it feels very unstable. It crashes more than any other software i own.
Below are some other random annoyances/bugs that I've noticed so far - i realise i am a newbie so if these are user errors then I'm very happy to be educated on the matters. I should also mention that I'm using Logic pro 9 on mac osx 10.8.2.
OK… in no particular order.
Crashes often (especially during slice mode)
An example of a guaranteed way to crash the program. Save a program using Logics 'save as setting' command. This method of saving is very useful as it means that presets can be accessed from logics side brower. I save presets this way in all other synths includingg UVI player with no problem. If you save a preset in Machfive3, and then try to load it in using the logic sidebar browser ,the whole system crashes instantly. Every other synth/sampler works fine & UVI player works fine too. It's a fundamental part of the logic workflow for many users and it means that you can load a patch in, without needing to open the synth.
Altering a sample to 'slice' mode *sometimes* adds artefacts (clicks to end of slices etc) even when played back at the original pitch. It shouldn't.
'convert' button in slicer doesn't seem to work. You have to drag it on top of it's part or onto another part. If you drag it onto itself it loses the 'main' sample which means no ability to drag the MIDI.
Zoom issues:
MIDI select (often called 'follow' in other programs) is good for showing the currently played slice, but it loses the zoom setting. For example, if i zoom into tighten the start and end points of a slice and then play the next slice - it jumps back out to full zoom and remains there. Going back to the previous slice now requires zooming in all over again. It needs to remember the zoom settings of the last time you visited that slice - or at least keep the current zoom amount.
speaking of zoom - why no simple zoom icons/shortcuts? I just had to buy a new mouse because the zoom didn't work with the apple magic mouse!! it works now , but would also benefit from a simple 'zoom to selection' icon. How can a modern sampler not have that basic feature? (maybe i just can't find it)
Also, in slice mode, the scroll wheel 'zooms' into the waveform, yet at other times it horizontally scrolls left/right through the waveform. The behaviour needs to be consistent. I would much rather the scroll wheel always zoom in/out - without holding a modifier key. Horizontal scrolling on mouse should do just that - scroll the waveform.
Danger:
If you select 'save program' in the list menu - it's very easy to destroy your sample. There is no warning that you are about to overwrite your .wav and replace it with a M5 program. I accidentally destroyed some samples of mine. I realise it was a newbie error but i would have welcomes a 'are you sure' at least (or even better forced me to give it a new name).
Losing samples:
Once you've converted your loop to slices and mapped them across the keyboard, i've found that SOMETIMES logic loses the samples when i reload the project the following day etc. I guess I am meant to save the program as a new program…but fast workflow shouldn't require that. For example, if i tweak a sound in a synth , it saves it with my project - when i reopen the project, the synth is in the same state that I left it - even without me doing a 'save as'. (i.e. total recall) even in a more complex program such as NI Battery - if I drag samples into a battery kit and edit them I do not have to save the kit - the kit is recalled exactly every time i boot up the project. Same with Stylus etc. To have to save the program every time you tweaked it would be a massive workflow destroyer….
A typical scenario for me would be dragging a sample from the desktop into Mach5 and simply instantly playing it. 1) open MF3 2) throw sample at it 3) close MF3 and play the sample on the keyboard. I do not expect it to have to save the program each time.
I also have thousands of beats… I want to be able to throw a loop into MF3, map it across the keyboard in one click and start playing it. I don't want to have to resave a whole new program for every single loop. that would end up with duplicating thousands of loops in 'mapped' format… but that's kind of pointless as there would be no way to preview these mapped loops because they would become m5p format and wouldn't play in the usually way. (i.e. i'd have no way to preview the whole loop)
As i say, losing it's samples has only happened a few times - not all the time. I expect it's something that i am doing wrong.
Other:
Autoload (in the main browser) seems to have no effect on m5p libraries?
Machfive plays when i don't want it to! no matter which track I'm on in my sequencer, when i press spacebar to play the track - Machfive starts playing too! I can't figure out how to turn the damn thing off, apart from just removing it.? i've tried pressing all the 'auto play' kind of buttons. It's as if they are both sharing the same 'play' command. help!
If you flick between sample mode and stretch mode, it remembers the settings (start & end points etc) But if you flick between sample mode and slice mode , when you return to sample mode it's lost its settings. Annoying.
Can you please confirm that if you load a sample loop in that has NO time data (ie not Rex nor Acidized Wav), and then go to slicemode, set the slice points, and go to "save sample" - it creates a Wav with timedata - but it doesn't do anything else weird to the sample? If this is the case then excellent - this is really handy for me for converting my loops to timecoded ones to preview 'in time' with Machfive3.
I'd appreciate to hear any thoughts on these matters. I would love to feel confident enough with the stability of MachFive3 to use it in my main working projects.
Thank you
Dale
Zoom issues:
Danger:
Losing samples:
Other:
Thank you
Dale
