Hi there,
I purchased Ethno Instruments 2, and after many many hours/days attempting to install it various ways i simply cannot get it to load properly. (I'm running Mac OS X Yosemite Version 10.10.4. Macbook Air 11" Early 2014. 1.7 GHz Intel Core i7 / 8 gB 1600 MHz DDR3/ with plenty of drive space). I'd very much like to have Ethno 2 run in Logic Pro X, but for now I'm even happy with just being able to run it using the standalone Ethno 2 application..........
Here's what I've tried already:
1st, i followed the method outlined in the supplied paper manual (ie. running the Ethno Installer first, then copying the .ufs sound banks to my computer, then connecting the iLOK license - still no success.)
2nd, I re-installed using the method recommended on various forums where the Sounds are downloaded first, then the installer. Still the same results. (Initially, i tried installing everything from the supplied discs, then after zero success I downloaded the updates from the MOTU site. Still the same lack of success.)
(i should mention that the iLOK key is in the computer the whole time when i've tried the '2nd' method above.)
Re: the Standalone Ethno 2 application: The error message ' Unable to mount the Volume from '/Library/ApplicationSupport/MOTU/Ethno/Ethno 2.ufs' ' appears when i open the standalone Ethno Instruments 2 application (& of course no sounds appear).
I've also tried creating aliases and installing them in the file ' /Library/ApplicationSupport/MOTU/Ethno ' and/or the file '/Library/ApplicationSupport/MOTU/Ethno/Ethno 2.ufs' but i can't seem to locate where this file is, or any file similar to this......
So, I understand that, when the Ethno 2 standalone application menu is empty and i get the above error message, the standalone sampler can't find the .dat and .ufs file, and it is necessary to manually point to their direction by creating aliases and placing them in the above described folder, but i don't get very far with this because i can't even locate the /Library/ApplicationSupport/MOTU/Ethno file.........
If anyone can help me with getting my purchased copy of Ethno 2 installed, I will be so very grateful
Huge thanks in advance to anyone and everyone who can help
Best, Bri
