Bidule is no longer being compensated for by DP's ADC. I'm using the "Bidule ReWire MIDI module" in Bidule and selecting "Plogue Bidule Device : Bus 1-Bus:1 Chn:1 (and so forth)" as the MIDI instrument in DP 7.24. I know it used to work. What am I doing wrong? Also, didn't Bidule instruments used to sync to tempo? I was certain that they did, but they're not now.
Can anyone help? Thanks!
ADC and sync-to-tempo not working in Bidule [Solved]
Re: ADC and sync-to-tempo not working in Bidule
Bumping this old thread.
I figured out that as long as I don't use Waves L3 on my mix Bidule plays in sync. Kind of a bummer, but at least I can work around it. However, I'd still like to get Bidule to sync-to-tempo.
Has anyone found a way to get Bidule to receive tempo-sync from DP?
In case anyone else has this issue, from the Bidule board I got:
Duh. Yep, that works!If it's through ReWire, you should normally be able to set Bidule ReWire as the sync source for any plugins requiring it (you will see a sync dropdown appear in the toolbar added by Bidule at the top of the plugin window).
If you are using Bidule as a standalone, you'll need to send MIDI Clock from DP and use a MIDI Clock To Sync inside Bidule to transform that into a sync source.
