File compatibility between DP8 and DP7?
beautypill
Post by beautypill »
Do you need to worry about backwards compatibility now? Or is everything Kosher on this front?
Lemmeknow.
cheers,
c
kgdrum
Re: File compatibility between DP8 and DP7?
Post by kgdrum »
beautypill wrote:Do you need to worry about backwards compatibility now? Or is everything Kosher on this front?
Lemmeknow.
cheers,
c
James posted a file re: themes for DP7 that you need to replace after you go from 8 back to 7 to retain themes,it's here somewhere.
David Polich
Post by David Polich »
Other than the themes issue (older 7.24 themes and Andy's GUI mods, which
do not work at all in DP8), I've found no compatibility problems going between
7.24 and 8 - so far. In fact, you can create a project in DP8, save it, and
then open it in 7.24.
And, as others have pointed out, after you first launch DP8, close and quit,
and then launch 7.24, all of DP8's new plug-ins show up in 7.24. This is
awesome for those of us who wanted the new plugs more than anything else,
and who want to continue in 7.24 for the time being.
7.24 and 8 and co-exist happily on your computer and you can go back and forth between them without any trouble.
http://www.davepolich.com
>7.24 and 8 and co-exist happily on your computer and you can go back and forth between them without any trouble.<
Well that is sweet. At least till some of my 32bit plugs become 64bit.
Unless... you're running in 64 and 32 bit mode, respectively, in which case your 32 plugs will not appear in DP8.
zed
Post by zed »
David Polich wrote:And, as others have pointed out, after you first launch DP8, close and quit,
Oh... this is the first time I've heard this. I had just finished stating that I would probably avoid this upgrade for a couple of months, but this little nugget of information has me thinking twice again. I would love to play with some of the new plugins.
I am impressed that MOTU set things up so that you could go back to DP 7.24 and still utilize the new plugins. That is pretty smart planning! I also like that we don't have to worry about saving DP8 files in a special way in order to open them back up in DP7. Again, that is really cool, since there are obviously going to be some growing pains here. It's nice to know that we can keep going strong in the stability of DP7 if we need to.
Billgonzo
Post by Billgonzo »
So I have DP8 on my PC but when I try to open a dp8 project on dp7 it didn't work. Do I need to save the project in some special way. I also tried saving then project as dp6 but the file still won't open on dp7.....I would love some help
Asus G73SW
Intel i7 2630QM Quad Core
8gb DDR3
x2 1TB HDD
FantomX8 Workstation
Billgonzo wrote:So I have DP8 on my PC but when I try to open a dp8 project on dp7 it didn't work. Do I need to save the project in some special way. I also tried saving then project as dp6 but the file still won't open on dp7.....I would love some help
Not quite enough information but I'll take a whack at it. If you a straight copy of a project from one computer to another, you will have problems. This includes uploading it to Dropbox or copying the file over the network.
You need to zip it first. Zip your project on the PC, then copy it over to the Mac. Unzip it and open in DP 8, save and it should now open in DP 7. It may open in 7.24 without opening in 8 first but that is not a given. BTW, you can install DP 8 on two machines that you own but the DP 8 license manager phones home and will only allow you to run it on one at a time. Make certain that, when you authorize another machine, you enter your name, license code and email address exactly the way you have it registered with MOTU - spelling counts.
This is not just PC to Mac. I is also what you do with Mac to Mac or PC to PC. DP is sensitive to file ownership and permissions. Also, this preserves the headers - straight copying does not. There are many threads on this issue.
If you are leaving the project on an external drive and swapping that, do Get Info on the drive from the Mac OS and check Ignore Drive Ownership and Apply to enclosed files.
If the preject is small enough to email, that also works.
Prime Mover
Post by Prime Mover »
Yeah, the updates are such that there are no new changes to the file structure. New commands are added to manipulate your data, but they are the same kinds of data read by DP7. So it's completely fine to open a DP7 project in DP8. Unfortunately, some of the features I'd like to see in the future would require some project data overhauls, though.
— Eric Barker
Eel House
Billgonzo
Post by Billgonzo »
ok so what your saying is that to open a dp8 file that was saved on a windows machine , i must first open the file in dp8 on a mac and save it before i can open it in dp7? this sucks cuz im working on a project for school and they only have macs with dp7 and my home setup is windows based dp8 so i cant install the dp8 demo onthe macs at school....
Asus G73SW
8gb DDR3
x2 1TB HDD
Billgonzo
Post by Billgonzo »
ok, so i opened my windows DP8 poject on a Mac with dp8 and then saved two versions, one as a dp8 project and one as a dp6 project....unfortunately i still could not open the project in dp7. the file is not recognized and when i try to open it manually, the project file is grey and i can't select it....it what im trying to do impossible? is this because im using a 64bit DP8 instead of 32bit?
Asus G73SW
8gb DDR3
x2 1TB HDD
