Toast 11.1 Upgrade hangs - Here's the solution
Posted: Sat Sep 01, 2012 5:50 pm
There is an upgrade to Toast, 11.1. It has many fixes, a few new features etc. which I won't bother you with.
Many users are having problems running the updater, however. It hangs and won't let you finish. Here's the solution:
Locate the "com.roxio.toast.plist" file in User Library/Preferences and delete or move to the Trash. Now the updater will work.
If you are like I, you will have run the following commnd in Terminal after updating to 10.7 or 10.8 and can just go to your User library anytime (not an issue in 10.6.x): chflags nohidden ~/Library
Otherwise, you must do the following:
1. Quit the Toast.app Setup Assistant
2. In Finder, click the pulldown GO menu and click GO TO FOLDER (or press SHIFT+COMMAND+G)
3. In the Go To Folder window, type (or paste) in: ~/Library/Preferences
4. Locate the "com.roxio.toast.plist" file and delete or move to the Trash
5. Close the window and launch Toast Titanium again
6. Proceed through the Setup Assistant as normal
No doubt, Roxio will fix this or at least post the solution in Support but, till they do...
