Page 1 of 2
Mainstage and DP7.24
Posted: Thu Feb 23, 2012 6:06 am
by p.pan
Hi,
I just realise I can do that:
On My Macpro see my signature.
Launch Mainstage buffer 32 with Superior Drummer Trigged By Edrum TD9KV.
Launch DP 7.24 Buffer 1024.
and surprise I can record my MIDI Edrums in DP.
Two differents Buffer on the same Computer.
Somebody know That????
I am very happy I can put My G5 away.
Just wait after the Apollo.
![Love :love:](./images/smilies/love.gif)
Re: Mainstage and DP7.24
Posted: Thu Feb 23, 2012 9:30 am
by stubbsonic
Would you mind giving us more details on how you interconnect them? I think those instructions would be helpful under this subject line.
Posted: Thu Feb 23, 2012 10:24 am
by p.pan
Sorry,
On a single computer a MacPro.
I have DP and Mainstage.
Audio interface Konnekt 24D.
I start Mainstage put my template Sdrummer Live.
Buffer 32 in the preference.
By the MIDI (Edrum TD9) I trigge the sound of Superior Drummer (Live).
In configuration sessions I open DP, MIDI Track With the MIDI assignement (In my case TD9).
(The buffer size In DP Is 1024).
And I record the MIDI of my drums with the sound live from Mainstage.
There Two different buffer size on two differents softwares in the same time on the same machine.....
Interssing No????
Posted: Thu Feb 23, 2012 11:44 am
by stubbsonic
That's really interesting, so is there no latency or is the latency fixed when the track is laid down?
Am I understanding it that DP is sending MIDI info to MS2, and MS2 is sending audio back to DP? Then you print the audio and it is lined up with the MIDI on the DP track?
Posted: Thu Feb 23, 2012 2:54 pm
by bayswater
Maybe a coincidence. At 48K, 32 sample delay in and a 32 sample delay out, would still be less than normal MIDI latency.
Posted: Thu Feb 23, 2012 4:11 pm
by Michael Canavan
Yeah that's pretty cool, I guess the easiest way to deal with it IMO would be to eventually instantiate an instance of Superior Drummer in DP and point the already recorded MIDI tracks to that soft instrument instance then bounce to disk. This gets around any problems with setting a buffer size too small in DP with a big project etc. and allows DP to have a big buffer with lots of plug ins etc.
Cool thinking, I'm going to have to pick up Mainstage 2 one of these days, but version one should work just fine for this as well.
Posted: Thu Feb 23, 2012 4:57 pm
by mjmoody
If you're opening SD Mainstage, I don't see how DP can be getting the MIDI info.
John
Posted: Thu Feb 23, 2012 9:01 pm
by p.pan
Hi,
To Mjmoody:
DP get the info by the same MIDI input in my case TD9Kv.
TD9KV--to---Mainstage (Buffer 32) With SD--Konnekt 24D (audio Out)
--to-- DP record MIDI track
What is nice I didnt struggle with the buffer size in DP is stay at 1024.
When I finish to record the MIDI in DP I just need to affect on the MIDI track Out the right VIs (in my case SD).
Let me know.
Posted: Thu Feb 23, 2012 9:08 pm
by p.pan
Sorry guys for my bad english.
But I think its very good think.
We dont need to deal with the buffer size in DP.
Posted: Thu Feb 23, 2012 9:55 pm
by cuttime
I can get a 16 buffer in MainStage with a 1024 in DP, however I still can't figure out how to publish MIDI outs in MS2. I can do it the other way with IAC.
Posted: Fri Feb 24, 2012 12:16 am
by p.pan
To Cuttime.
I use the same MIDI in (In my case TD9 but he can be any other MIDI device on the "MIDI Audio set up) on the two applications.
Today I try with a bigger session on DP (with MIDI tracks VIs in Playback) and keyboard play on Mainstage.
I let you know.
Posted: Fri Feb 24, 2012 1:31 am
by p.pan
It work only with VIs you can load in DP.
You use Mainstage only for to play.
And you determine the buffer size you want.
For exemple when you finish your MIDI track recording with the Edrum (MIDI track in DP).
You need to open an instrument track with SDrummer in DP.
And affect the MIDI track to SDrummer.
If you use templates a bit quicker.
Posted: Fri Feb 24, 2012 2:49 am
by Michael Canavan
Cuttime you don't have to route MIDI between DP and Mainstage at all, this is a way to record MIDI tracks from virtual instruments live at the lowest buffer you can, while keeping a huge mix project with AU's all over the place in DP at a 1024+ buffer size if you want.
Again you set up a MIDI track in DP to the same MIDI controller you're using on a virtual instrument in Mainstage, thereby getting to use a low latency buffer size to record the MIDI. Afterwards you turn around to DP and instantiate the drum AU plug in and point your MIDI track to that plug in.
![Smile :)](./images/smilies/icon_smile.gif)
Posted: Fri Feb 24, 2012 6:35 am
by bayswater
So is this basically the same setup that was posted here and at MOTU some time ago for using Garageband and Logic instruments in DP, except that you're using Mainstage instead of GB/Logic, and putting 3rd party VIs in Mainstage?
Posted: Fri Feb 24, 2012 9:34 am
by stubbsonic
I'm having a hard time understanding this, but I REALLY WANT TO UNDERSTAND IT.
What I do understand: DP & MS2 are both open. DP is recording MIDI. MS2 is getting MIDI from the same source as DP. MS2 is being used to live monitor the sounds with less latency than DP.
Is that correct?
What I'd like to understand is some basic ways to make DP & MS2 communicate so I can access MS2 sounds (and possibly effects) even if there is latency-- as long as latency can be compensated later. But, am I hearing that this would provide a work-around for latency while tracking?
