How to enable SMART : Solved
kgdrum
Post by kgdrum »
Hi I cloned my boot drive w SuperDuper:
journal extended
Both drives are same exact make model etc....500 gig WD black 7200
I am planning to get the hd mount kit to install the drive to the empty 2nd optical bay(hope not too complicated)
anyway...
I have the drive running via USB & noticed it says SMART status not supported.
Is this because I have running via USB? or did I clone it incorrectly?
How do you enable SMART status?
Or is it just need to be used SATA?
KG
kgdrum
How to enable SMART
Post by kgdrum »
Never mind just talked to OWC
SMART status not supported externally via USB
macguy
Re: How to enable SMART : Solved
Post by macguy »
Did you go with Maxconnect or OWC? I have the MC and works great (in my iMac).
kgdrum
Post by kgdrum »
going to do the OWC mod, nervous about removing the fan & hooking cable to logicboard but it should be easy enough to diy.
it will be nice to have a cloned boot drive mounted internally ready just in case......
