hi everybody,
I searched the forum for an answer and didnt find one.. please let me know if I missed something.
I have a problem with my MOTU 828mk2 firewire. It used to work great and I used it with 2 computers (PC and Mac).
Now when I connect the firewire cable from the computer to the sound card the clock indicator (sample rate) begins to flash... the computer does not identify the sound card as a sound device.
I tried it with 3 computers and 4 different cables - same results.
other then that, it works fine when I connect some inputs and use the internal mixer to route the sound out (but I don't need a mixer:)
if the computer is connected when the sound card boots, the boot process get stuck.
you can watch a quick demo that I made here-
http://www.youtube.com/watch?v=AiUcCZpJITo" onclick="window.open(this.href);return false;
spec:
iMac 27, i7, OS 10.6.8, connects via FW cable 9 to 6 pin
PC, IBM T60p,Win XP, connects via PCMCIA FW card, 6 pin to 6 pin cable
I have tried to:
1. do a factory reset
2. play with the voltage button when it was disconnected
3. tried using the card both with 110V and 220V
Any advice will be appreciated!
Thanks,
Itai
Motu 828 mk2 - clock indicator is blinking
