DP problems with Apogee Duet?
i've installed the latest drivers for the Duet, plugged it in. It doesn't seem to want to work with DP projects that i have. It will work with a new project, but with any others, DP opens and then bouncing ball... basically then nothing happens. i've tried different buffer settings and diff work priorities in Hardware setup. i'm also using VE Pro. This is disappointing..
anyone?
anyone?
Computer/s: OSX 10.8.3
2 x 2.66 GHz Mac Pro Quad-Core Intel Xeon w/ 16GB RAM,
DAW:DP8.05
Hardware: Apogee Duet
VI's/Plug-ins:
Kontakt 5.1, EW PLAY Libraries and a
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
Re: DP problems with Apogee Duet?
Tried loading old project into new session. When i went to change the outputs from the old (828mkII) in italics to the Duet, yep, permanent bouncing ball of death. This is really frustrating. What else can i try?
DAW:DP8.05
VI's/Plug-ins:
million others.
DAW:DP8.05
VI's/Plug-ins:
million others.
You really need to call Apogee Tech Support.
I have an Apogee Duet - no problems on my system.
http://www.davepolich.com
- burn em
no problems here either.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
I've run into problems with my Apogee Rosetta when the clock is set differently between DP and Audio MIDI Setup. I don't know if ths is your problem, but it might be worth checking out. Go to Audio MIDI Setup and see if the clock rate for your Duet is set the same there as your DP projects. Worth a try.hrw wrote:Tried loading old project into new session. When i went to change the outputs from the old (828mkII) in italics to the Duet, yep, permanent bouncing ball of death. This is really frustrating. What else can i try?
Phil
FWIW how many drives etc. do you have on your FW bus? My Duet was working fine until I added a third external FW drive to my bus in addition to the Duet. I think it might be a FW bus power issue.
In any case I went back to the 828 and my Duet went back to laptop duty.
Tobor
Tobor
If i ever have any issues with Duet I make sure to have Maestro running and "Refresh Connections" in the drop down menu. It always clears up any sync issues there might be. It also helps to have a saved Maestro profile that you can load to kind of reset any weirdness.
Various analog front end gear-> Apogee Rosetta 800->Quadcore 2.2 GHz MBP/OSX 10.13.6->Rosetta->HR824's, Apogee Duet,Various FW HD's,
Yamaha CL5> Dante Virtual Soundcard> Mac mini, DP 10.01
