Tripi wrote:Hey James, thanks for the good investigative work. I've been through this a few times, and changing the file extension does work. Although, when I get a cue with 10 different stems of surround tracks, it would take a lot of typing to adjust them all.
I hear you. it's just what you gotta do unfortunately. As a workaround however, I suggest you check out Rename. It's free and it should be able to do the file extension renaming for you. Especially if it's just inserting the "x" character just before the ".wav" part of the file name. There's a preview window in the app that shows you how it will change the files. It would spare you all that typing.
http://www.pathossoftware.com/Rename/Rename.html" onclick="window.open(this.href);return false;
The main reason I'm importing them 1 mono track at a time is because when I drag the surround stems (or even 1 file from it) in to the Tracks Overview area, DP creates a quad track and a stereo track. I can't find anyway of telling which channels are on which tracks. I'm assuming it does it correctly.... but I can't just guess on things for this project.
Well that's interesting. As I said, I've never worked with surround so I'm only taking a guess at this. I wish my friend had more time to answer directly. One thought would be that you might try creating a surround track first, then drag one of the surround files (other then the .L or .R files) to the the surround track and see if that doesn't prevent the creation of a quad and a stereo track, but all six channels remain in the surround track.
Again, I don't know anything about working with surround, but I'm assuming if you have created a surround bundle and correctly assigned each channel in the bundle to the intended discreet output on your audio interface, you could test that this has then imported correctly. Certainly someone has made a nifty surround bundle that has soothing female voice going one at a time through all the various channels, saying "left" through the left channel, then "right" through the right channel, "center" through the center channel and so on so that you can verify correct placement?
The other reason I wanted to do it this way was so I could change my audio prefs to WAV format, and just drag the files and use them, without writing a new format and taking up double the disk space.
Does WAV not support surround extension like that? Are you not receiving the files with the correct naming conventions? I don't understand. Again, caveat, I don't do surround.
Another problem is that I need to be able to switch takes on different channels, and having them all together in one surround track won't let this happen. It's just a real shame that what I'm hearing, and what I'm seeing displayed in DP don't jive. It makes me nervous that things are being reported incorrectly. I wouldn't want to use any other daw besides DP for this project.... just means taking a lot longer to do.
Someday I'll figure this all out. Just don't tell any of my clients I'm winging it in the mean time.
Well then as my friend suspected, you have a specific reason for breaking them out into individual mono tracks, thus I think you really have to just bite the bullet perhaps and break that implied "link" by altering the file extensions. Try Rename. I think it will save you a lot of typing. It could be that you're just using DP in a way the programmers hadn't envisioned (i.e. switching "takes" on just one channel of surround audio) and perhaps in the future there's something they can do to make this usable. I could see something like this being useful on stereo tracks as well, as people working in stereo have run into this issue. Perhaps some sort of command like "Explode audio channels to separate tracks" could be invoked that would unlink stereo or surround audio and break them out into individual mono tracks?
Again... if you know changing the file extensions works, I'd maybe give Rename a shot.
