DP 7.23 hangs and crashes...
DP crashed a bunch of times... I tried to repair permissions, clean preferences in DP/Motu (I am using an ultralite as interface).
Running sessions from the internal drive (I am in a macbook pro, core 2 duo, 4 Gb ram).
It´s a totally clean system... I got a bunch of different errors...
Any advice would be appreciated!!! Thanks!!!!
Garlu
Here is the last report (I didn´t copy the whole thing because I crashed on thread 0):
Process: Digital Performer [230]
Path: /Applications/Digital Performer 7.23.app/Contents/MacOS/Digital Performer
Identifier: com.motu.DigitalPerformer
Version: 7.23 (7.23)
Code Type: X86 (Native)
Parent Process: launchd [130]
Date/Time: 2011-06-21 20:44:20.490 -0700
OS Version: Mac OS X 10.6.7 (10J869)
Report Version: 6
Interval Since Last Report: 150187 sec
Crashes Since Last Report: 25
Per-App Interval Since Last Report: 18461 sec
Per-App Crashes Since Last Report: 11
Anonymous UUID: 0FE20A97-A311-4BA9-AF14-83F3A44EEE05
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Thread 0 Crashed: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0xffff088c __memcpy + 236
1 com.apple.CoreGraphics 0x97886fd8 CGSFillPortStreamWithData + 96
2 com.apple.CoreGraphics 0x97886f61 CGSDispatchDatagramsFromStreamWithData + 32
3 com.apple.CoreGraphics 0x97886c36 snarfEvents + 460
4 com.apple.CoreGraphics 0x978868ed CGSGetNextEventRecordInternal + 141
5 com.apple.CoreGraphics 0x97886806 CGEventCreateNextEvent + 66
6 com.apple.HIToolbox 0x94bdf916 PullEventsFromWindowServerOnConnection(unsigned int, unsigned char) + 112
7 com.apple.CoreFoundation 0x904cb772 __CFMachPortPerform + 338
8 com.apple.CoreFoundation 0x904c74db __CFRunLoopRun + 6523
9 com.apple.CoreFoundation 0x904c5464 CFRunLoopRunSpecific + 452
10 com.apple.CoreFoundation 0x904c5291 CFRunLoopRunInMode + 97
11 com.apple.HIToolbox 0x94c07e04 RunCurrentEventLoopInMode + 392
12 com.apple.HIToolbox 0x94c07bb9 ReceiveNextEventCommon + 354
13 com.apple.HIToolbox 0x94d90084 _AcquireNextEvent + 54
14 com.apple.HIToolbox 0x94d85d40 RunApplicationEventLoop + 228
15 com.motu.DigitalPerformer 0x007c3ca4 SndBiteStripTimeScrollMouseWheelHandler::Clone() + 746724
16 com.motu.DigitalPerformer 0x00022ec2 0x1000 + 138946
17 com.motu.DigitalPerformer 0x00022de9 0x1000 + 138729
Garlu
Report Version: 6
Re: DP 7.23 hangs and crashes...
10 min later... another one (this time thread 44, that one was really common yesterday...):
Process: Digital Performer [294]
Date/Time: 2011-06-21 21:27:27.907 -0700
Report Version: 6
Interval Since Last Report: 152774 sec
Crashes Since Last Report: 26
Per-App Interval Since Last Report: 20053 sec
Per-App Crashes Since Last Report: 12
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000002
Crashed Thread: 44
Thread 44 Crashed:
0 PerfFoundation.dylib 0x0216ba53 BufConverter::Create(AudioFormat const&, AudioFormat const&, DitherType) + 6603
1 PerfEngine.dylib 0x01d885d3 PerfAudioStats::PerfAudioStats() + 4553
2 PerfFoundation.dylib 0x021bfce7 GetUnitTestRandomLong() + 259
3 libSystem.B.dylib 0x9116f7fd _pthread_start + 345
4 libSystem.B.dylib 0x9116f682 thread_start + 34
Report Version: 6
Crashed Thread: 44
Thread 44 Crashed:
Again Thread 44... Any idea?
Process: Digital Performer [202]
Parent Process: launchd [122]
Date/Time: 2011-06-21 22:43:42.292 -0700
Report Version: 6
Interval Since Last Report: 155987 sec
Crashes Since Last Report: 28
Per-App Interval Since Last Report: 21107 sec
Per-App Crashes Since Last Report: 13
Crashed Thread: 44
Thread 44 Crashed:
Report Version: 6
Crashed Thread: 44
Thread 44 Crashed:
- kassonica
Can you post what system you are running and what 3rd party plugins you may use.
Thx
Thx
Also run a test on your RAM.
http://kelleycomputing.net/rember" onclick="window.open(this.href);return false;
I have just run a RAM test with techtool and seems to be fine. Also, on the mac specs says "ram ok".
Plugins, I don´t have that many installed now... I did a clean install of everything this weekend.... I am using VE Pro (8 instances on the v-rack) and one kontakt on the session I am working on. It´s a big template though, with a lot of MIDI tracks and just one audio file as reference. No video though.
My system specs:
MacBook Pro 3,1 (i think), from late 2007
2.2 Ghz
4 Gb Ram
SL 10.6.7
DP 7.23
Internal HD is a 500gb, 7200 rpm.
Audio interface: MOTU ultralite, driver 1.6, firmware 1.15
I repaired permissions on the main HD booting from the SL install disc, but it didn´t do the trick...
Thanks a lot for your comments though!![Smile :)](./images/smilies/icon_smile.gif)
My system specs:
2.2 Ghz
4 Gb Ram
SL 10.6.7
DP 7.23
Hmmm... Not familiar with the RAM test in techtool. Hopefully it's thorough. You might double check with Rember. It is free.
Thanks for the tip!James Steele wrote:Hmmm... Not familiar with the RAM test in techtool. Hopefully it's thorough. You might double check with Rember. It is free.
It says "all good!" hehehe.
I am getting crazy here trying to solve it...
Thanks for the help everyone!
- kassonica
What are you running in Kontakt?
WHat is the sample rate and bit depth for the project?
For now, just a hollywood winds major scale patch.kassonica wrote:What are you running in Kontakt?
48 khz/ 24 bit.
Let me know what you think it could be...
- kassonica
I'm not that good at reading these crash reports yet, but this stands out,
Thread 44 Crashed:
Disable Kontakt and see if the project is stable.
It maybe that the samples in Kontakt were/are 48/24 and your project is 44/24....
Just guessing really....
Thread 44 Crashed:
Mmm... interested.... never heard of that...
I should try though... Thanks for the suggestion! I will try it tomorrow, it´s pretty late now...
I will let you know guys!
Thanks again!
Thanks again!
Not sure if this is the acute problem, you could have some actual hard- or software problem crash your machine. But even on a clean system, unless the project is super-simple, you should really never run DP sessions from the same drive you run DP and the OS from. (If you're running Kontakt, sounds like you may also be streaming samples from the same drive as well?)
Try putting the project folder (and possibly your Kontakt library) on an external FW drive, and I'd suspect there would be some improvement in stability right away. (Of course this would do nothing to fix a possible corruption problem or similar.)
Kubi
Kubilay Uner
http://kubilayuner.com
MacPro 2x2.8 GHz Quad-Core Intel Xeon, 20GB RAM; OS 10.9.5; DP9.01; MOTU 2408mk3 & MIDI Express 128 w/latest drivers
Kubilay Uner
I am streaming from an external drive...
About the session, I always though, for a laptop, it was better to run it on the internal drive... probably I am wrong then... I will check it later...
I am thinking even on starting from scratch from a clean template, and then "move" the MIDI data.
Thanks for the input guys!
Old templates have burned a lot of folks around these parts over the years. A fresh template may be the ticket to a stable system. Good luck!
