Firewire Drive brings Mac to it's knees?
buzzsmith
Post by buzzsmith »
Just noticed a few days ago that my studio Mac started acting randomly sluggish.
I'd get the beach ball in DP and an attempt to save to my less than 6 months old external FW backup (Iomega® UltraMax Single Desktop Hard Drive 1 TB) would give me an error message. Even dragging a little .gif to it would be rejected as would trying to eject it from the desktop.
I shut down the computer, turned the drive off and replaced it's cable.
Rebooted and everything seemed fine, except Apple's Disk Utility said it needed repair which it did judging from the progress list.
Still noticing, on occasion, that I'm having some issues. I don't think it's a FireWire issue, but this drive in particular. It seems to want to power down (sleep?), and I have not checked that in any preferences. Nothing is supposed to power down, ever.
I'm presuming that I may have a bad drive...just curious why it seems to affect the entire system.
Thanks...
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
daniel.sneed
Re: Firewire Drive brings Mac to it's knees?
Post by daniel.sneed »
Can't help much, just sharing.
My new 1To external drive brings many unexpected behaviors when connected thru FW: no boot, mac hangings, HD disappearings, app hangings, but all is fine when connected thru usb.
It's already been warranty serviced once, but will be twice... or more!
Falcon, Kontakt, Ozone, RX, Unisum, Michelangelo, Sparkverb, Soundtoys
buzzsmith
Post by buzzsmith »
I'm trying USB, now. Just had a freeze a few minutes ago, but it was so frozen that I could not open the iomega to see what it was showing and if might have been the culprit.
I was simply trying to trash an item from the desktop when it froze.
Backing up data VERY soon from this drive.
Buzzy
Focal Twin6 Be(s)
burn em
Post by burn em »
Back it up now! That drive is probably on it's way out. Good luck
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
Do you happen to have some sort of camera on the same FW bus? There can be bandwidth contention leading to file corruption on FW drives in that situation, even if the camera is inactive. The original iSight was a good example.
buzzsmith
Post by buzzsmith »
No camera on this Xeon. However I will double check to make sure iSight is inactive. I believe that's an option.
Some quick research indicates that there are complaints about the power supply to these drives.
I have everything I want to back up in a folder. First thing in the morning.
Buzzy
Focal Twin6 Be(s)
Have you tried popping the drive out of its enclosure and running it in your tower?
buzzsmith
Post by buzzsmith »
mikehalloran wrote:Have you tried popping the drive out of its enclosure and running it in your tower?
I may have the terminology wrong but is it a slide and plug SATA drive like the 3 I have within the Mac?
(see sig)
Thanks...
Buzzy
Focal Twin6 Be(s)
If a newer enclosure, it should have a 3.5" SATA drive inside. This will pop into one of your bays.
If the internal drive is PATA/IDE, then no.
At 1T, I would expect an SATA drive inside.
