10.6.7
nick danger
Post by nick danger »
I just ran software update, and there is a system update. Haven't installed it yet, or looked for a combo update. I'll update this post if/when I find one.
Edit--
Link to combo updaterr
http://support.apple.com/kb/DL1361" onclick="window.open(this.href);return false;
iMac 2.66 GHz Intel core 2 duo, 8 gb ram running 10.11.6; 17" Macbook Pro 8,3, 2.5 GHz Core I7, 16 GB ram running 10.13.6; DP 8.07; 8pre-es; 828mkII; 828mkI; microbook II, Behringer ADA8000, Black Lion Auteur 2-Ch. Pre-Amp
Frodo
Re: 10.6.7
Post by Frodo »
Hey Nick:
Be sure to share you thoughts in this thread, which was merged from two threads.
http://www.motunation.com/forum/viewtop ... 26&t=45812" onclick="window.open(this.href);return false;
Thanks.
Frodo
Re: 10.6.7
Post by Frodo »
First oddity with 10.6.7: it killed my home wireless network. Same settings, same everything on all machines. "Connection Failed" all around.
nick danger
Re: 10.6.7
Thanks, Frodo-- good to know. I hadn't pulled the trigger yet. I think I'll wait a bit.
twistedtom
Re: 10.6.7
Post by twistedtom »
My computer is on Ethernet and it asked me to set up my net connection, strange. I have not opened DP or much today so I hope all is well. :smash:
nick danger
Re: 10.6.7
My main computer is also on an ethernet cable, although it is routed through the Airport Extreme that creates my wireless network. There was no interruption of that signal, but other computers on the network could not immediately connect wirelessly. I had to reboot all the Airport Extremes and Expresses that are part of the network. After doing that, everything worked fine.
Phil O
Re: 10.6.7
Post by Phil O »
My Airport network working fine here. No interruptions.
Phil
Frodo
Re: 10.6.7
Post by Frodo »
Power cycling all devices helped sustain an on-again-off-again internet connection which had required some prodding with Network Preferences to stay afloat.
But-- I'm still baffled by not being able to restore remote access among machines.
