DP 7.22 Kontakt 4.1 volume control problem
Posted: Fri Feb 25, 2011 4:12 pm
Hi,
I am new to DP but has been reading this forum for awhile. I am using 7.22 with Kontakt 4.1 and recently encountered a rather weird situation.
On some of my projects, I could not control the volume of Kontakt without leaving the VI window open. That says, when I close the VI window, and try to move the volume slider in mixer window, there is a short clip sound and a short stop of the VI playing, and then the volume remains the same. Also when I close a opened Kontakt window, the clip sound and the short stop happens. However, if I leave the Kontakt window open, everything resumes normal.
I have tried to isolate the possible causes of the problem by:
1. Creating a new project: things will get back to normal, but at one point, this situation comes up.
2. Deleting the original Kontakt and creating a new one: Does not work.
3.Change my audio driver (from Apogee Duet to System audio): does not work.
I searched the forum but did not find previous posts regarding to similar situation. Has this happened to anyone here? Is there something I can try to further identify the cause of the problem?
Thank you!
aztic
Thank you!
aztic
