Help! Can't set up Vienna Ensemble Pro network with DP
Posted: Mon Feb 07, 2011 5:04 pm
Hello, I am a total noob when it comes to setting up networks. Hopefully someone here can point me in the right direction, I'm sure it's a simple problem.
I just bought a brand new MacMini and put a SSD in it and am trying to use it as a slave running VE Pro connected to my MacPro as the master running DP 7.2.
There is no router involved, it's just these two computers with a crossover ethernet cable. I can set up file sharing, so I know the cable is working, but when I run VE Pro the master can't find the slave in the setup window... Do I need to change the IP addresses or anything? I'm so confused. Please help if you have any ideas
Thank you in advance.
