DP has trouble recognizing .dv file. HELP
- berlinpigeon
My DP has trouble recognizing the Quicktime .dv file. When I export it as a movie file (by the way it becomes, twice the size), I can import it, but the size of the picture/movie changes. I never had this before, so any help is greatly appreciated!
Thank you!
Christian
Thank you!
Christian
- berlinpigeon
Re: DP has trouble recognizing .dv file. HELP
I actually mean that it is changing the dimensions, when I import. Thanks!
- FMiguelez
Sorry if this is too obvious, but do you mean the actual size of the window changes?
If so, you can control the display size within the QT window mini-menu to whatever you want.
- berlinpigeon
haha...nothing can be too obvious when in comes to audio post. I actually mean, that it changes from 16:9 to 4:3 (roughly) when I import it into Digital Performer . Never happened to me before.
Thanks for your reply!
C
C
I get that too, but that is only an issue if viewed on the Mac. Using a .dv file is fine to output through firewire to a display, where you should be able to set the aspect to widescreen.
If you are only viewing on the Mac, you don't need to have such a large .dv file.
Cheers
Stephen
Cheers
Stephen
http://www.chimera-arts.com
http://ostinatomusic.com
http://stephentayler.com
- berlinpigeon
Thank you Stephen! Since I don't have a firewire device output, I will request a different codec for the final cut (which I will receive next week). Then it should work all fine.
Cheers!
C
Cheers!
C
