Page 1 of 3
Can DP 7 receive MIDI output from a Instrument plug-in?
Posted: Fri Oct 29, 2010 4:25 pm
by Christopher Drake
Does anyone know if DP can receive MIDI output from a plug in?
For example in my case I have MASCHINE loaded as an instrument, and want to record enable a MIDI track in DP to record MASCHINE's instrument MIDI output, as demonstrated in this tutorial at NI:
http://tinyurl.com/28g8vkg" onclick="window.open(this.href);return false; (it's the fourth marker in the video, to skip to the part relevant to what i'm talking about)
I can make this happen in PTHD, but I don't seem to have any MIDI input available from the MASHINE plug in on my DP input drop down.
any ideas???
Re: Can DP 7 receive MIDI output from a Instrument plug-in?
Posted: Mon Nov 01, 2010 8:04 am
by 1nput0utput
Yes, Digital Performer supports MIDI outputs from plug-ins. The Trigger plug-in is the oldest one I can think of. Keep in mind that the plug-in won't be active if the track where it's inserted doesn't have a valid audio output, and that would probably cause the plug-ins MIDI output to not be published. Also check whether Multi Record is enabled or disabled. In most cases, you would want it disabled, but it might be helpful to enable it for your purposes.
Posted: Mon Nov 01, 2010 11:15 am
by dewdman42
I'm not so sure. Trigger is MAS. The question is whether DP supports MIDI output from AU plugins. Does AU even support that? I thought I read somewhere that only VST supports that and AU does not, or something like that. I could be wrong.
Posted: Mon Nov 01, 2010 2:12 pm
by adriano
dewdman42 wrote:I'm not so sure. Trigger is MAS. The question is whether DP supports MIDI output from AU plugins. Does AU even support that? I thought I read somewhere that only VST supports that and AU does not, or something like that. I could be wrong.
Hi dewdman42,
No! DP does not support MIDI out from AU plugins. They can be programmed to support that like VST plugins. Below is the link if interested:
http://lists.apple.com/archives/Coreaud ... 00053.html" onclick="window.open(this.href);return false;
The only thing is that MOTU has to implement the code into DP also, so that it knows how the AU plugin is being used.
The truth is that not even Logic is programmed for MIDI out functionality. Not one DAW supports this.
I have MDrummer, VST and AU. Both plugins support MIDI out, but the only one that I can use is the VST version and have to load it in Metro from sagantech, same with RealGuitar plugin.
I sent a feature request for DP, Logic and Metro a month ago about this and heard nothing yet except for Metro which, will be ready in a few days.
Here is another ongoing thread at musiclab makers of Realguitar:
http://www.musiclab.com/community/forum ... php?t=2942" onclick="window.open(this.href);return false;
Hope you've found this somewhat informative
Posted: Mon Nov 01, 2010 2:24 pm
by dewdman42
I guess the only way to deal with MIDI plugins is the host them in a different host somehow and route MIDI around with IAC. You get some MIDI jitter that way, but it kinda works. yea hope MOTU will get with the times too. Jamstix is coming out soon on OSX and that one in particular I will be wanting bad to use with OSX.
Posted: Sun Nov 27, 2011 4:06 pm
by adriano
Hello forum,
Just revisiting this thread and wondering if, there is some kind of plugin (AU) to load in DP or standalone app that will load VST with MIDI out functionality and pass/record the output into DP.
Adriano
Posted: Sun Nov 27, 2011 5:15 pm
by FMiguelez
Hi, Adriano.
I'm at a loss here. I don't even know what this thread means
Do you think you could briefly describe what the OP means and wants, please?
Why would I want to recieve MIDI OUT from a AU plugin? Could you give me an example? Just trying to understand this...
Maybe it's something useful I should know about?
Posted: Sun Nov 27, 2011 5:30 pm
by MIDI Life Crisis
Well the power behind making a sound in a VI is MIDI data. So if you want that data somewhere else, simply copy the track and assign the data to your destination. I'm not sure why you might otherwise want to monitor that directly from the VI.
Can you give us an example as to what you're trying to accomplish?
Posted: Sun Nov 27, 2011 5:35 pm
by Gravity Jim
Ditto FM and MLC.
Are you talking about running a plugin as a standalone module and capturing a performance "downstream" in DP? Because if you run a VI hosted within DP, I can't think of any value in being able to get MIDI Out.
Posted: Sun Nov 27, 2011 5:40 pm
by adriano
Hi FM,
I'll do my best to be as clear as possible.
RealGuitar for example from Musiclab, the VST plugin version has MIDI out capabilities. What this does is making it General MIDI compliant. Here is a link, if interested in some reading:
http://www.MIDI.org" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Trying to strum a guitar on keys for a standard MIDI file, is not an easy task, but, RealGuitar implemented "MIDI Out" feature about a year ago and it works very nice.
I hope I explained it right
Adriano
Posted: Sun Nov 27, 2011 5:57 pm
by Kubi
There are a number of plug-ins where this would be useful, i.e. algorithmic Reaktor ensembles, etc. Sounds like this is a shortcoming in the AU spec?
Posted: Sun Nov 27, 2011 6:03 pm
by MIDI Life Crisis
Then there is MachFive 3 and scripting to consider if it's strumming you need.
Posted: Sun Nov 27, 2011 6:14 pm
by adriano
MIDI Life Crisis wrote:Then there is MachFive 3 and scripting to consider if it's strumming you need.
Thanks for the info, MLC. I will email Dave at Motu to find out if MachFive will output to MIDI according to the GM specs.
Adriano
Posted: Sun Nov 27, 2011 6:18 pm
by MIDI Life Crisis
I was referring to the scripting for strumming in M5, not outputting MIDI. That would still be a function of DP as per my earlier post. I have to look at your links when I'm on my Mac. On the iPhone since Thursday.
Posted: Sun Nov 27, 2011 10:10 pm
by Michael Canavan
The biggest reasons for MIDI out from an AU would be drum sequencers, arpeggiators, and unique step sequencers. Not to mention an AU's internal grooves etc.
Couple examples:
Reaktor- there are some really unique step sequencers in Reaktor, maybe you want to have another soft synth follow the sequence, or to have the other AU be the only sound etc.
Geist (Guru before) is a great drum machine AU, really nicely laid out exclusively for electronic drums, it's pretty cool to be able to send out the Kick/snare or whatever MIDI hit from Geist to control one of the many drum synthesizers in another track, etc. etc. This way all your percussion sequences stay inside Geist.
It would of course also open up the playing field for third party MIDI plug ins, arps etc.
For some reason it's not being implemented in AU even by Apple with Logic apparently, but it's a great feature of VSTs and it really should be.
