Omnisphere, RMX, Trilian Users!
minimoog
Post by minimoog »
Has anyone else noticed that the option to run spectrasonics VI's
"in realtime" no longer exists?
not sure if why,..but try all 3 and see.
can't be good news, since spec suggests that's the way to run them in DP.
Mac Pro Quad 2.66|9GB|Macbook Pro dual core 2.4|4GB|
OS 10.6.4|DP 7.21|Apogee Ensemble & Duet|
Re: Omnisphere, RMX, Trilian Users!
minimoog wrote:Has anyone else noticed that the option to run spectrasonics VI's
It's still here in my copy of Stylus RMX. Version 1.9.4d (32 bit) of Stylus running on DP 7.21.
What version of DP are you using? If the problem is that the menu isn't opening where the options appear, Ctrl-Click the gray oval in the title bar of the plug-in window at the upper right to see the menu.
minimoog
Post by minimoog »
thanks James, latest versions of everything,...I didn't know I had to ctrl click to see the options to run realtime,.that was it.
It didn't used to be that way, the lil mini menu used to drop down.
thx for the help though!
minimoog wrote:thanks James, latest versions of everything,...I didn't know I had to ctrl click to see the options to run realtime,.that was it.
It *shouldn't* be that way. There's a graphic glitch with the Spectrasonics stuff that needs to be fixed. Ctrl-Clicking the oval is a workaround until it gets sorted out and the mini menu works again with those plugs. :D
minimoog
Post by minimoog »
oooohhhh!
ok
thx
BobK
Post by BobK »
Thanks for the tip, James!
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 15.4
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
GlennO
Post by GlennO »
James, if you haven't already done so, please report this problem to MOTU. Thanks.
Glenn O
Spectrasonics
GlennO wrote:James, if you haven't already done so, please report this problem to MOTU. Thanks.
Hey Glenn... they're aware of it and I'm pretty sure they're working on a fix on their end. :)
