Timepiece MTP AV SYSEX List and Modifiers for Windows
Posted: Wed Sep 29, 2010 5:25 pm
Everybody knows that there is a mystery about the System Exclusive Messages for Timepiece AV, or how to program MTP AV. Motu's support say they never published it, but somebody at Motu has this list and could post it at Motu's website. I think is a Timepiece owners right to have it.
Anyway, I started to dump the communication between my computer and MIDI Timepiece and I could figure out some SYSEX command to program MTP-AV and how to create, name and save some setting on modifiers.
These are the commands that are already defined and can be send by any sequencer:
1 - Channel Re-Mapping
2 - Mute Notes/Multichannel Settings
3 - Mute Data
4 - MIDI Input/Output Routing
5 - Global Setup
6 - Sync Part 2
7 - Sync Part 1
8 - PANIC
9 - Write Block
10 - Set Pedal - Can be saved/called on a Modifier
11 - Set Knob - Can be saved/called on a Modifier
12 - Name Setup/Modifier
13 - Select Setup
14 - Select Modifier
15 - Clear Modifier
16 - Select Patch
17 - Configure Patch
The text with the complete commands and syntax is too long to post here. If you like to know how to use then, I save it as a PDF on my web site and the direct link to download it is:
http://www.adrstudio.com/motu/MTPAV-SYSEX_1_0a.pdf
Feel free to use it because they are just others resources of Timepiece AV !!!!!!!
3 - Mute Data
5 - Global Setup
6 - Sync Part 2
7 - Sync Part 1
8 - PANIC
9 - Write Block
13 - Select Setup
15 - Clear Modifier
16 - Select Patch
