naming a sample??
Posted: Fri Aug 13, 2010 7:24 am
by sampa
Good morning all. Is it possible to name something we sampled? or does the sample name have to remain (temp 1, temp 2 etc.) ??? thanks
Re: naming a sample??
Posted: Fri Aug 13, 2010 7:43 am
by FMiguelez
Of course you can rename anything you recorded anything you like.
Have you looked this up in the Manual or the Getting Started Guide? It's one of DP's most basic and elementary things, really...
Posted: Fri Aug 13, 2010 9:39 am
by sampa
thanks - just to be clear I am talking about motu bpm- not dp
Posted: Fri Aug 13, 2010 9:44 am
by FMiguelez
Woops....
Sorry about that!
I keep forgetting that I'm looking at NEW posts from ALL forums and not just DP
Posted: Fri Aug 13, 2010 9:52 am
by sampa
lol - no problem.
Posted: Sat Aug 14, 2010 9:49 am
by b-righteous
Currently there is no sample rename. You do have the option to save a sample in the file menu under save pad sample as. Of course the sample has to be assigned to a pad for this. It would be nice to have a rename option in the clip window's right click menu.
Posted: Sat Aug 14, 2010 11:42 am
by saintjoe
yes, being able to rename it in the clip window after sampling would be dope.
honestly, I don't sample with BPM at all, I just haven't really warmed up to how it handles sampling, slicing, etc.
Posted: Sat Aug 14, 2010 7:45 pm
by b-righteous
Oops! I forgot about the menu button of the clip window. There is a save as there so you can save the sample with a new name before you map it to a pad. This is not a rename and will save a new sample. No need to worry though because all new samples are stored in a temp folder and deleted when you close BPM. You then have an option to save the temp samples. If the samples are mapped to a kit, you can save them with the kit with the save kit + samples command. You can also save it with the whole project with the save project with samples command. This will save all assigned samples with the project and all the temps can be purged when you close BPM if you choose not to save them.
It would still be nice to have a rename option in the right click menu but you can get by without it.
Posted: Sun Aug 15, 2010 9:23 am
by saintjoe
no doubt, save as is cool for sure, like you said, a quicker way would be rename, then move it to the pads and save as with the kit, just a small workflow enhancement, but like everything else in BPM, there's still a way to make it work for ya
