about 1.5
Posted: Tue Aug 10, 2010 8:13 am
by sampa
Hello all - I just want to be clear about something. The only actual new content as far as sounds go is the beat box anthology...is this correct.? All other new genres are based on patterns of the sounds that we already had in v.1 ? Thanks.
Re: about 1.5
Posted: Tue Aug 10, 2010 9:13 am
by joker77
The new Uvi Soundbank uses new presets + sounds from Anthology along with. I uninstalled the previous Bpm + soundbanks, and reinstalled using the new ones..Mine works perfectly.There are new sections NOW- kits+patterns that we're present in 1.0,are in a folder called - HipHop-RnB,plus theres a bunch of new folders,and presets.If your a windows user, wanna be safe,uninstall and reinstall as mentioned in the manual.ENJOY!
Re: about 1.5
Posted: Tue Aug 10, 2010 9:17 am
by joker77
Also for what it's worth the Anthology bank is better then the one I bought,the kits are all filled up
![Wink :wink:](./images/smilies/icon_wink.gif)
Re: about 1.5
Posted: Tue Aug 10, 2010 9:23 am
by sampa
Anthology is definitely great!!! I am on a mac, I did not uninstall the old version. I just intalled 1.5 then replaced the ufs soundbanks with the new ones. I hope i didnt have to uninstall first. oh well but it seems everything is woking fine so far so i guess on a mac there might not be a need to unistall the old version??
Re: about 1.5
Posted: Tue Aug 10, 2010 10:03 am
by joker77
see below
Re: about 1.5
Posted: Tue Aug 10, 2010 12:43 pm
by ssp
on the mac uninstall first then install the new update, this is in the pdf manual also.
Re: about 1.5
Posted: Tue Aug 10, 2010 1:18 pm
by sampa
I am on the mac - i did not uninstall. Do you think I should redo everything? I dont think i had a problem. Also SSP can you confirm the sampling bug? thanks
Re: about 1.5
Posted: Tue Aug 10, 2010 3:57 pm
by ssp
If I get a chance to at some point tomorrow I will check it out for you, I am upto my eyeballs in electronics at the moment testing this new hardware I am making. As soon as I can I will see what happens for me.
Re: about 1.5
Posted: Fri Aug 13, 2010 3:40 pm
by FrankW
I believe the uninstall was/is more PC specific. I did not uninstall. I'm on a Mac...
Re: about 1.5
Posted: Sat Aug 14, 2010 2:47 am
by ssp
Frank, every revision on the mac while testing was uninstalled prior to installing the next update. on the pc it just over-wrote.
