FYI: ADS Pyro A/V Link Video Converter Compatibility
Posted: Fri Jul 23, 2010 6:18 am
by Saintmatthew
I noticed the frustrating experiences have had with incompatible device(s) with DP for external video monitoring and thought I'd help the cause. I picked up this very reasonably priced unit a couple months ago to sync video for live performances and it works good with DP 6.03 on mac (10.6-SL). Device was class compliant os no driver install was required. Don't have v7 so I can't give a 100% guarantee of compatibility but I can't see it breaking as v7 seems good to go. It does require using DV codecs though-I haven't had any luck with non-DV codec files although I haven't made it a personal quest to try either. Just throwing it out there for anyone afraid of what to try.
Re: FYI: ADS Pyro A/V Link Video Converter Compatibility
Posted: Tue Aug 17, 2010 11:59 am
by musicinstincts
Hello,
I have been using the pyro A/V link box for over 6 years now. I do notice that sometimes it makes my mac (2.8 8 core) struggle with firewire. By this I mean that, it doesn't like my digi 002 very much. They do work together but it takes a couple of boots someimes. Nice device. I was almost about to buy another video card (I'm extremely comfortable having three screens) but someone told me that I should just buy another firewire card instead. My question, would this relieve my firwire bus and make another? Two seperate firewire buses?
Anyone?
Posted: Wed Aug 18, 2010 7:19 am
by Saintmatthew
Not sure. It probably wouldn't hurt to run them on separate FW busses. So far mine has played nice with my 828 MKII. Which is first on your chain? I have the 828 first on mine.
Posted: Wed Aug 18, 2010 7:26 am
by musicinstincts
Thanks for your reply!
I'm not sure if I mentiones but I now have a Mac Pro 2.6, 8 core. Still gives me the same problems. I have the 002 on the back and the pyro in the front. My understanding is that it is the same bus. Am I wrong?
Thanks again!
Oscar
Posted: Thu Aug 19, 2010 9:56 am
by Saintmatthew
I'm pretty sure it's the same bus but you might want to check and make sure. if you have 400 and 800 ports those might be different busses. I use a macbook with only one port so I daisy chain mine. I don't have anything Digidesign to test with though so that might be the culprit.
Posted: Tue Oct 26, 2010 6:32 am
by Doctor
Hi,
I'm not aware of nor do I know what this link and converter do, but I have solved some of my firewire problems.
Back when I used a PPC g5 quad, I purchased a couple of Tango FW and USB cards. I hooked my Lacie 800 FW drives to the main computer 800 FW port, hooked each of my 896mk3 audio cards to the two installed FW 400 cards.
This may or may not help solve your problems, but it might as it does separate and make each card an individual FW buss plus your computer FW as a third buss..
Good luck.
