aftertouch with minimoog v
Posted: Wed May 19, 2010 8:33 am
by steve_56
Using DP6 with Arturia Minimoog V installed as a plug in. When using the Minimoog as a stand alone the aftertouch works fine, but I can't get it to work in DP. The mod wheel and pitch bend are working fine so I know the sysex is turned on - just can't seem to find the settings in DP to trigger the after touch.
Thanks for your help!
Re: aftertouch with minimoog v
Posted: Wed May 19, 2010 9:03 am
by 1nput0utput
steve_56 wrote:Using DP6 with Arturia Minimoog V installed as a plug in. When using the Minimoog as a stand alone the aftertouch works fine, but I can't get it to work in DP.
Check the MIDI Input Filter dialog, which is accessible from the Setup menu.
steve_56 wrote:The mod wheel and pitch bend are working fine so I know the sysex is turned on - just can't seem to find the settings in DP to trigger the after touch.
Neither mod wheel nor pitch bend are system exclusive events. Mod wheel is a control change and pitch bend is a unique type of event (although it's practically a 14-bit control change).
Posted: Wed May 19, 2010 11:39 am
by steve_56
Found it! ThanXXX
