Urs tape saturation
Posted: Tue Feb 16, 2010 7:15 pm
I am demoing this plug and it seems really good, anyone else try this out yet ?
https://www.motunation.com/forum/
I must agree. I listened to the audio samples on their website and they just sounded bad to me. The "before" sounded better than the "after."mhschmieder wrote:..I personally found that it colours and distorts the material in every case, even at light settings, so decided not to buy it...
Once you work with this plug-in you learn how to dial it in. It's like any other tool: You need to spend some time with it to learn how and when to use it and all its idiosyncrasies. The presets can be a bit heavy handed but they give you the overall sense and flavor of that particular saturation and then you dial it up or down or around from there. It's a combination or melding of the different levels and flavors of saturations that make it special, not so much a per instrument/track basis.Phil O wrote:I must agree. I listened to the audio samples on their website and they just sounded bad to me. The "before" sounded better than the "after."mhschmieder wrote:..I personally found that it colours and distorts the material in every case, even at light settings, so decided not to buy it...
I dunno, maybe it's just me.
You can't trust those demos. I get much nicer results working with the plugin on my system.Phil O wrote:I must agree. I listened to the audio samples on their website and they just sounded bad to me. The "before" sounded better than the "after."mhschmieder wrote:..I personally found that it colours and distorts the material in every case, even at light settings, so decided not to buy it...
I can't find the examples on their website. Can someone please provide a link?Phil O wrote:I must agree. I listened to the audio samples on their website and they just sounded bad to me. The "before" sounded better than the "after."mhschmieder wrote:..I personally found that it colours and distorts the material in every case, even at light settings, so decided not to buy it...
I don't know where those are. I've never heard them. I would suggest downloading the demo and giving it a spin. The true test will be using it on the tracks you're working on.dix wrote:I can't find the examples on their website. Can someone please provide a link?Phil O wrote:I must agree. I listened to the audio samples on their website and they just sounded bad to me. The "before" sounded better than the "after."mhschmieder wrote:..I personally found that it colours and distorts the material in every case, even at light settings, so decided not to buy it...
There is nothing to learn on the URS plugin. You either like the results you get or you don't. That said, I believe that the source material matters very much with the use of saturation plugs. We all record differently and in many cases for different audiences so what is acceptable within a mix is highly subjective. I find that in a dense rock/metal mix that the character it imparts is very favorable. If the surrounding instruments were cleaner then I might feel differently.mhschmieder wrote:Haha, I got worse results dialing things in myself than what I heard of their on-line demos.Guess I have a lot to learn about using sat plugs.
