Success!
Phil O
Success!
Post by Phil O »
Wasn't sure where to post this, but I wanted to share this with you.
I have an old project that I had just about given up on. It won't open in any versions of DP. It causes a crash when I try to load chunks from it. In short I thought it was toast. So, I tried opening it in DP7.1. It almost works, but the file opens to a transport control and that's it. Nothing works and no other windows will open. But then I got a surprise. The auto-save feature kicked in and saved a .autosave version and to my surprise that version opens properly. :D
I guess this could be a technique to try as a last resort for corrupt project files that will open but won't play.
HaHaaaaaa! Take that, you nay sayers!
Phil
FMiguelez
Re: Success!
Post by FMiguelez »
EEEEEAAAAA!!!
That's awesome, Phil!
Who would've thought? Auto-save, huh? 8)
I'm curious if the fix was due to auto-save per se, or if you could have rescued the project by simply saving yourself.
This needs to go to the Tips Sheet!
Dan Worley
Re: Success!
Post by Dan Worley »
O Happy Day. What a great surprise.
Congratulations, Phil.
Now finish the dang thing. :)
c-ya,
Dan Worley
DP10.13
Phil O
Re: Success!
Post by Phil O »
FMiguelez wrote:I'm curious if the fix was due to auto-save per se, or if you could have rescued the project by simply saving yourself.
I thought of that. The Save command was greyed out because you couldn't make any changes to the project with no windows open. It was a catch 22.
Phil
FMiguelez
Re: Success!
Post by FMiguelez »
Phil
Cool!
So your trick, let us call it "the Phil trick", is to let auto-save kick in for projects that won't load and seem lost for ever.
Nice workaround to be aware of 8)
