Room tone generator?
Digital Perfomer in the context of television/film scoring and post-production.
bongo_john_uk
Post by bongo_john_uk »
Didn't DP used to have a room tone generator? I am sure I noticed it back in the day when I didn't really need it as was doing mostly music.
Now I have switched to mostly processing film sound, it would be very handy but I can't find it in verson 6 which is what I am using.
Mac Pro 12 core 3 GHz, Motu Ultralite, DP9.1, Mac OS X 10.10.5 64GB Ram.
http://limbicsounds.com
dp-user
Re: Room tone generator?
Post by dp-user »
That would be the "Smooth Audio Edits..." feature, which can be found in the Audio menu. Basically, you select a couple edits that are spaced apart (with silence between them), and you tell DP to "Smooth" the edits, and it places room tone between them.
It does not synthesize room tone (that's very hard to do), but rather find room tone (either automatically from the file, or from a file you specify) and either stretches or boomerang-loops it to fill the void. It's a very common technique in audio post, but DP basically automates it.
To be honest, the couple times I've tried it it hasn't worked so well, though. Still, YMMV, and post your findings after you've had a chance to give it a whirl...
