Hi Fi Itunes through DP trick
stephen1212b
Post by stephen1212b »
Ok not a trick really but very useful patching. When playing iTunes instead of listening to the output directly try returning a mix back to DP via cuemix (in my case using a Traveler) that includes only the feed from the computer, ie just the iTunes. In DP set up a stereo track to monitor the input of the returned mix. Set up a master with Master Works Limiter inserted and select 24 bit with dither and noise shaping. Assign this to a different output than the default which is being used for the iTunes round trip. You now have a useable digital volume control that sounds great because it is turning 16 bit into dithered 24. Of course you can insert EQ to help your speakers or your room. Try an expander to relieve those over compressed Cds. My favorite and most needed is the polarity reverse. I assign the output to the SPDIF digital out and use a better quality DAC than those built into the interface. This will sound better than using the digital volume control in iTunes and may allow you to replace a preamplifier, many of which have very poor volume controls. Apple lossless or AIFF are great choices.
Now who has some ideas to provide remote control of DP from an iPhone instead of just a MIDI controller?
Mac OS X version 10.5.8 / DP 7.12 / Dual 1.25 GHz G4 2GB DDR SDRAM / MOTU 2408mk3 / Powerbook G4 / traveler
buzzsmith
Re: Hi Fi Itunes through DP trick
Post by buzzsmith »
stephen1212b wrote: Now who has some ideas to provide remote control of DP from an iPhone instead of just a MIDI controller?
Check out "LogMeIn". It's a little pricey and a little slow/sluggish (not "snappy" :D ) since the commands travel from your iPhone through the net and back to your Mac, but it has it's uses.
You can't play notes with it, but you can control (and see) DP or whatever app you want to remotely control.
(The iPhone screen mirrors your Mac screen.)
My piano is upstairs from the workstation, so sometimes I'll use it (with a remote USB keyboard) to visually verify that I'm actually in record.
Not the perfect solution, but one anyway.
Buzzy
Yamaha C7 Conservatory Grand
Hammond B-3 / Leslie 145
Focal Twin6 Be(s)
KEVORKIAN
Post by KEVORKIAN »
I'm using Jaadu VNC for this. It's the best vnc client I have found for the iPhone. Much cheaper than logmein (which is a powerful service but may be overkill if you are in the same room with your computer)
http://www.jaaduvnc.com/
dp7.2 || os 10.6.7 || 2x2.8 (eight core) intel mac pro, 16gb ram || metric halo uln-8 || motu traveler || euphonix mc control || waves mercury || abbey road bundle || mh channelstrip || toontrack sd 2.0, ez drummer, drumtracker || addictive drums || drumcore 3 || ni komplete 5 || reason || bidule || altiverb 6 || omnisphere, stylus RMX || melodyne 3.2 || stillwell || soundtoys || nomad factory|| psp || mpressor || dsm ||
stephen1212b
I am using ROWMOTE at the moment. It is only $5 and provides mouse and keyboard control over the computer. It is just hard to click on effect bypass buttons by dragging a mouse pointer from across the room.
I started setting up a custom control panel so I can at least make the controls bigger targets.
What I am looking for is a way to set up a keyboard shortcut that could be mapped to a volume control or an effect bypass. Ideally it would effect things the way MIDI can without needing to make the controlled window active. That way iTunes could stay in full screen mode even while the polarity or the volume was being changed in the BG.
Does anyone know of a MIDI controller app for the iPhone?
KEVORKIAN
Post by KEVORKIAN »
stephen1212b wrote:I am using ROWMOTE at the moment. It is only $5 and provides mouse and keyboard control over the computer. It is just hard to click on effect bypass buttons by dragging a mouse pointer from across the room.
I see. You could check out ProRemote... It's a control surface app that I don't use becaue I have a Euphonix and can't use both...
newrigel
Post by newrigel »
There's tons of VPN stuff for the iphone (Jaadu VNC) that you can see your monitor and use your fingers to mouse around on the macs desktop to remotely control it.... I just HATE doing that because if I ever lost my phone... but I have the remote wipe etc. but still, the VPN thing is a bit hacker prone. Maybe just get a used ipod touch just for that purpose only and keep it in a safe place.
