Monitoring inputs always on
alekc
Post by alekc »
It seems as though monitoring the inputs can not be switched off in Cuemix on my UltraLite MK3. I've switched off all the monitoring options on the inputs (apart from main outs) and I always hear the signal coming into the analog ins. This happens when using it in conjunction with GuitarRig & Audition.
I'm sure it's me doing something wrong, but I don't know where...
Please help,
alekc
Re: Monitoring inputs always on
Post by alekc »
:bump:
happy boxing day.
NazRat
Post by NazRat »
Don't have the stuff in front of me, but I would suggest setting the Mix Bus output to 'none' or what ever is the equivalent of no pair.
DP8.06 PT11.2.0 VEP 5.3.x
alekc
Post by alekc »
thanks for the reply. i'm no where near my system, so i can't check it out, but i remember switching the monitoring off on every channel. i can't remember where the output goes to or if i've switched it off. i'll check it out and post the result.
thanks.
alekc
Post by alekc »
i've had the time to check it out. i hadn't checked all the busses in the drop down menu and one of them hadn't been muted. thanks for pointing me in the right direction.
happy new year.
