Wait on DP7 update if using Vocalign
miditime
Post by miditime »
Just though I'd warn you - before you update to DP7 - if you use Vocalign with DP6 a lot. (I did.)
It is presently broken / disabled in DP7.02 - and will hopefully be fixed in the next update.
You can still drag and drop into the stand alone Vocalign & import aligned files back to DP.
(Ouch!)
The installation of 7.02 somehow renders previous versions of DP unable to communicate with Vocalign as well.
Other than that 7.02 works amazing! (I miss Vocalign.)
