G5 users using DP 7.01 successfully... post here!
I saw a post today about DP 7.01 being unusably slow on quad G5 as compared to DP 5.13. I don't understand this. I'm using DP 7.01 on my dual G5 and it's not really much slower and it's completely usable.
If you are using DP7 successfully on a G5 Mac, please chime in.
Re: G5 users using DP 7.01 successfully... post here!
If you do NOT have DP7 running successfully on a G5-- please do NOT chime in!!James Steele wrote:.
- hammerman
I will chime in James. It is working great for me and look at the specs below! Best version ever! I will be getting a new puter when Apple releases the next round of towers probably early next year, but you can blame that on Spectrasonics;)
M2 Mac Studio Ultra - 64 GB RAM - Sequoia - DP 11
Working great here too - and not only DP7.01, but most other software including PT8 which also gets a lot of performance bashing. And that's with BFD, Kontakt, Reason - some demanding VIs and plugs. The dual PPC with 10.5.8 is probably the most stable, dare I say snappiest, combination I've had for audio. I realize it's no Intel box (I've seen those in action), but it's no slouch either. The single best performance bump for me was when I moved two drives (session and backups) to eSATA. I also have an extra firewire buss on an adapter board for the LM.
DP8.06 PT11.2.0 VEP 5.3.x
- burn em
working a treat here! G5 dual 2 ghz pci / 10.4.11 /DP7.01
I'm very interested in the prob's with quad G5's as I'm thinking of buying one.
Macbook Pro i7 17"-10.6.8 16Gb DP 7.24 ][ G5 dual 2 ghz pci, 4Gb-10.4.11 DP 7.12
Nomad Factory ][ Airwindows Gatelope (The best drums gate. buy it!) ][ Altiverb 6
MOTU 828 mkIII, 828 mkI x3, 8Pre ][ Apogee AD16, DA16 & Duet ][ MC Mix ][ API 3124+ ][ Toft ATB 24
working great !
G5 Dual Ghz 6 GB Ram
Works great for me James. DP7 now opens OMF files for me. Did not in 5 and 6 !
2012 6 Core 5.1, MacPro , (32 gigs Ram) Monterey, Radeon 570, 2013 MacPro #1 12 Core, (64gigs ram) ,2013 MacPro #2, 8 Core .(64 gig ram), Monterey, MacBookPros 2011, 2017 , 828MKIII Hybrid, 828X, MicroBook II, 8Pre, Nuendo 8ch A/D converter, PreSonus DigiMax LT , DP11 , PT 2024 , Cubase Elements 10.5, Peak 7, Logic 9 ,WaveLab 11, Reason 12, DSP-Quattro 5 ,many plugins , mics and synths. http://www.panaccimusic.com
- Woody
Everything working fine had some problems @96K with firewire out of Tascam DM-4800 but I bought another PCI-424 (should of never sold mine) and works fine
G5 PPC Dual 2 GHz,4 GB Ram,10.5.8,MacBook Pro 2.4 GHz Intel Core 2 Duo,2 GB,10.5.8,DP7.0.1,Peak 4,PCI-424 MOTU 2408 MkIII,MOTU MTP/AV,Tascam DM4800 w/FW Card and Surround,Lucid GENx6-96, Waves 7 Platinum,SSL 4000 bundle,Final Cut Studio,Quested VS2108's,Blue Sky 5.1,Drumcore 3,Misc mics and Instruments
I haven't pushed it hard, but have had few or no crashes on my G5 (see signature for system details).
For example: I edited, mixed and mastered three songs with about a half dozen mono audio tracks (44.1/24), Altiverb, a few MW EQs, a couple of Nomad Factory Pulse-Tech EQs, and a Nomad mastering limiter, and had no problems at all (tracking had been done in DP 6.02, I think).
Other than that, I've messed around a bit with VIs - mainly the Spectrasonics instruments and Kontakt 3.5 and had no problems as long as I turned off pre-rendering till I was ready to bounce the final mixes.
I opened some old large, complex all-audio mixes (around four dozen tracks, plus or minus) just to see how DP 7 handled them, and it did fine.
So...while I haven't pushed it hard, I've found DP 7.01 very stable. The live fades have made me more confident that it won't crash while I'm doing audio editing, which is a big improvement. In some informal tests, I found DP 7 to push the CPU Usage meter less than DP 6, but a bit more than DP 5.
Most importantly, since I've started using DP 7 I don't think I've had to go back to DP 5 once.
EDIT: One problem I forgot to mention is that the mixer GUI often behaves strangely - I forget exactly (will take notes and start a TechLink), but I think it was that the fader wouldn't move when I manually typed in a value for the level, and when I'd click the '+' or '-' icons to nudge the fader, neither the fader nor the value readout changed. IIRC, the level was actually changing; it was just that the GUI wasn't responding.
Bob
M1 Max Mac Studio - 64 GB RAM - macOS 15.4
MacBook Pro (15-inch, Mid 2012) - 2.6 GHz Intel Core i7 - 16 GB RAM - macOS 14.4 via Open Core Legacy Patcher
DP 11.23
Metric Halo ULN-8 mk4
DP 11.23
- climber
seems to be OK here so far. all my old files have opened and some are 40+ tracks with a lot of plugs including UAD, Waves, Glue, etc. resizing windows is abysmally slow however. dunno what's up with that...
Al Hospers
bass, vocal, composer
I gave up GearLust for Lent...
http://www.soundsclever.com" onclick="window.open(this.href);return false;
Scatterdust - http://www.youtube.com/watch?v=bQ-twe1LH2U" onclick="window.open(this.href);return false;
Inward Stroke: http://www.youtube.com/watch?v=VKHUx82GzzE" onclick="window.open(this.href);return false;
Clever Sounds Recording Studio
Mac Pro 8 core 3GHz, 7 GB RAM, FF800, Digital Performer 7.2, ISA428, ADL600, Distressor, ADAM-A7, Auratones, Ristola custom bass, lots of mics and other fun toys that keep me in debt!
Audio and MIDI working great. VIs are slowing it down so I am using Plogue Bidule (as in the other thread). Other issues include MachFive not working in Plogue Bidule (crashes audio system). Same results with M-Audio drivers as well as built in audio.
So M5 runs in DP - all others in PB. Seems ok, but again, in DP 7, loading VIs slows it all down way too much.
Dual 2.0 G5; 4 GB RAM; OS X.5.8
works here
Various analog front end gear-> Apogee Rosetta 800->Quadcore 2.2 GHz MBP/OSX 10.13.6->Rosetta->HR824's, Apogee Duet,Various FW HD's,
Yamaha CL5> Dante Virtual Soundcard> Mac mini, DP 10.01
