DP 5.13 plugin trouble: MAS, 0 error -> 211-10868
Posted: Sat Oct 24, 2009 8:53 am
by KOEN
Hello y'all,
after having a HD crash (but fortunately no data loss) I'm in the process of reinstalling everything on a new internal HD. When reinstalling the Abbey Road Bundle (Limiter, Master EQ and Brilliance pack), the Limiter does show up in DP 5.13, but between () - as in '(TG14313)'. When I click on it, it appears etc. but doesn't work. When starting up DP 5.13, I keep getting a "MAS,0 error reported by MAS Audio Unit Support, Failure: initialization 211-10868 <-10868>
Anyone any ideas or familiar with the problem?
I did check Ilok drivers, reinstalled the bundle for the umpteenth time etc.
Many thanks beforehand!
Koen.
Re: DP 5.13 plugin trouble: MAS, 0 error -> 211-10868
Posted: Mon Oct 26, 2009 11:34 am
by synchro
Which version of OS X did you install after putting in your new internal hard drive? Which model Mac do you have (RAM? Audio Card?)
After the re-installation of the Abbey Road Bundle and subsequent error in DP 5.13, did you try accessing the Abbey plug-ins using an audio editor like Peak, WaveEditor or other AudioUnits compatible app? If so, did they work?
Was there a point after you initially installed DP 5.13 that you were able to open it without an error? Or did the errors start after installing the Abbey plug-ins? Did any of the included MAS plug-ins work?
KOEN wrote:Hello y'all,
Koen.
