error - 39 ... i am so f#$%^ !!
few days after updating on snow leopard , i got a corrupted file , cant open a project anymore ...an error occured while redaing from the disk ... no back up ...i tried to open it in another computer same , tried to open it in MIDI only , and without anything else , i mean just the file itself ..nothing worked . i am really ••••ed !!! what a desaster , one week work gone !!!
any idea ? though i am quite pessimistic ...
pleeeease if someone has a solution ..
Re: error - 39 ... i am so f----- !!
See this:
http://support.apple.com/kb/HT2433
Type -39 error (Logical End-of-file reached during read operation)
The Macintosh was expecting a marker to show it where the end of the file is on the disk. That marker is either missing or is in the wrong place. A crash is the most common cause, however a disk error or corrupt file can also cause this.
Solutions: Recovering the file frequently fixes the problem. If it does not, make a clone of a backup, open the clone and try to import from the file that is giving the -39 error message.
In other applications, using an Import or Insert command from inside a new document frequently works around the problem. You also might move/copy the file to another volume.
Re: error - 39 ... i am so f#$%^ !!
Sorry to hear your problems. Hope you get it worked out. I edited your header. Watch your language here... thanks.arnopolaris wrote:few days after updating on snow leopard , i got a corrupted file , cant open a project anymore ...an error occured while redaing from the disk ... no back up ...i tried to open it in another computer same , tried to open it in MIDI only , and without anything else , i mean just the file itself ..nothing worked . i am really ••••ed !!! what a desaster , one week work gone !!!
- Mr. Quimper
Here's hoping MOTU implemented auto-backups in DP7.
I've never been able to recover a corrupted file, but some others have.
Good luck.
Good luck.
2.5Ghz Quad-Core/20GB DDR3/10.11.6/DP 9.5
yes sorry for the language ... but it is such a pain in the ...i alreday had that kind of problem but this time looks like there is nothing to do! grrrr
from now i will "save as" like a maniac !!
someone understand what apple guys mean by " Recovering the file "??
I'd also run disk utilities and make sure your hard drive that you are recording to is healthy.
i did this too unfortunately .. also tried on several different hard disk unfortunately no result ..thanks for trying to help me
I'm not sure what Apple means by the term, but this might be helpful:arnopolaris wrote:someone understand what apple guys mean by " Recovering the file "??
http://subrosasoft.com/OSXSoftware/inde ... ducts_id=1
You might try starting a new project and LOADING the chunk(s). Usually, -39 errors are fatal.
I'm sorry to hear about this.
Whenever I've put any significant amount of work into a session, I start using "Save a copy as..." periodically, just naming them by adding increasing numbers. The size of the session files themselves is negligible, and that way I have a recent version to go back to if something bad should ever happen. Basic backup practice.
ps--- If you;re running Leopard, Time Machine is your friend. No, make that your lover! It has saved my ass so many times now I've lost count.
- Dan Walsh
+100,000,000MIDI Life Crisis wrote:ps--- If you;re running Leopard, Time Machine is your friend. No, make that your lover! It has saved my ass so many times now I've lost count.
iMac 3.06 i3|OSX 10.6.8|8 gig ram||DP 7.24|Motu 896HD|2 Avalon VT 737's|Presonus ADL600|Slate VCC|Superior Drummer 2|EZ Drummer|1.1.6|Kontakt Player 4.1|Steven Slate Drums EX|SampleTank 2 XTAntares ATR-1|Presonus Central Station|Neumann TLM 103|Rode NT1|Audio Technica AT 4033 X2| Rode NT-5's|and lot's of other junk
thanks but unfortunately didnt work for that DP project filebillf wrote:I'm not sure what Apple means by the term, but this might be helpful:arnopolaris wrote:someone understand what apple guys mean by " Recovering the file "??
yes the only thing to do now is loading the audio in a new project and do everything again ..what a nightmare !
i will never forget to "save as" several time a day from now on !
thanks guys
thanks guys
