RAM For Recording...
bufdaddy
Post by bufdaddy »
I recently acquired an IMAC G5 (1.8 ghz.) and I am looking to purchase some RAM. I'm gonna probably go ahead and get 2 gigs. My question is what brands of ram do you recommend for both compatibility and quality. Some friends of mine have recommended Kingston and Crucial. I do know that the mac store is 4 to 5 times the price of a lot of brands I have looked at. Any advice?
westla
Re: RAM For Recording...
Post by westla »
Just make sure it's certified to run in a Mac. Other than that any brand will work.
daddyunicorn
Post by daddyunicorn »
OWC makes real good RAM. The longer you wait, the cheaper it is.
Dual G5 2.0 (pre-intel), 2408iii, DA7, WR-AD96, c1's, api312's, 10.4.10, DP 5.12, mach 5, Waves Gold., pc88, 2080, Reason 3, logic 8pro, Antares AutoTune, red lava lamp
MT
Post by MT »
Go with a name brand. Kingston valueRAM is not that expensive these days (picked up 1G pair at newegg lately for $83). RAM is one area where paying for name brand is worth it.
Good luck,
MT
G5 Dual 1.8 | LynxTWO A,B,LS-ADAT | 2-Bus LT | UAD-1 | DP 4.6, 10.4.5 | DFHS VC | Reason 3 | Site | 50/50 Films
"Blade... Laser... Blazer"
westla
Post by westla »
I wouldn't exactly consider Kingston ValueRAM a good choice. It's not certified for Mac's. I'd recommend Other World Computing also. You can get Mac certified RAM for a good price.
chrispick
Post by chrispick »
I don't know if Kingston is officially certified, but it definitely works in Macs. Post houses I've worked at have often preferred it -- and I'm using it right now in my G5.
westla
Post by westla »
Are you (and the post houses) using the Kingston VALUERAM or Kingston regular RAM?
I too have used the ValueRAM, but I've had a few bad experiences with kernel panics that were traced to the RAM.
just a thought.
MT
Post by MT »
I've never had a problem with it, in two AMD 64 machines and my G5. Of course, nothing wrong with buying better RAM if you can afford it.
MT
chrispick
Post by chrispick »
just a thought.
I think it's the regular. I say that, though, only because I didn't know there was a VALUERAM. That certainly sounds "less than high grade."
