Nope. To be clear, I don't use MIDI for anything, and it's one or more audio tracks which are record enabled when I find the conductor track record enabled. Can be anything from a single overdub track in the middle of the track order, to a stereo mix track at the end of the track order, to all currently created tracks for a live band take. Template, no template, doesn't matter. Anything here that's MIDI related is a stock preference I've never seen or changed.FMiguelez wrote:
Check if you have multi-record on for MIDI. That's the only way I know you can have more than 2 non-audio tracks record enabled.
Conductor track can take a hike for all I care
Re: Conductor track can take a hike for all I care
Doug Williams
Tape Op issue 73
DP 11.31
Studio M1 Max OS12.7.3
MOTU 16A and Monitor 8
Tape Op issue 73
DP 11.31
- Mr_Clifford
... or open a pre-existing Reason file via Re-wire, which hi-jacks the tempo if you're not in conductor mode.HCMarkus wrote: PS: it is a lot harder to accidentally change the tempo of a project when running off the conductor track. Just a thought for those who occasionally click in the wrong spot on the screen, or strike the backslash key (possibly with fist) repeatedly for no reason.
DP 9.52 Mac Pro 10.14.6 RME fireface800. Sibelius. Dorico 4
- Dwetmaster
Conductor track for life!!!
Cliff's situation happened to me all the time when I didn't use the conductor track...
The only way I could see myself put the conductor track accidentally is if I CMD clicked on a track's record-enable button. It'll disarm this current track and arm all other...
You can accidentally arm the Conductor track (or any other track) by arming a track and then using the up- and down arrows, thinking that i.e. you are using them to move up and down in a VI's preset list. This has happened to me a few times, though never with any consequences.
Of course the conductor track is essential. One of DP's strongest advantages over the competition.
I can't arm one track, use the up/down keys, and get additional tracks to arm. All I get is the armed track to disarm and change to the adjacent track. I am never losing the purposeful track arming, I'm keeping those and getting random additions of the conductor track armed. I'm never getting other audio tracks accidentally armed.
Doug Williams
Tape Op issue 73
DP 11.31
Tape Op issue 73
DP 11.31
- SixStringGeek
Its also harder to change it on purpose. Having come from ESQ-1 sequencer and Vision, I was used to the idea that a chunk has a fixed tempo. Select the chunk, then change the tempo in the transport bar and the chunk should now play at that tempo. That's the theory and it always worked before in other environments.HCMarkus wrote:it is a lot harder to accidentally change the tempo of a project when running off the conductor track
In practice, it was maddening because you change the tempo in the transport bar (and it lets you!), hit play or record, and the tempo changes back to whatever it was at when you recorded the thing in the first place. Which, for us keyboard challenged quasi-musicians who often record stuff at lower speeds, is really annoying.
I did eventually figure out the conductor track and now go there to edit tempo change events - but I can see how a new user would get very frustrated with this model - especially when the transport has that nifty tempo control that only works if the conductor track is empty.
DP 8.newest on MacPro 5,1 Dual Hex 3.33GHz 64G Ram, 3TB SSDs.
- Mr_Clifford
Option-T is your friend.SixStringGeek wrote: Its also harder to change it on purpose.
Yeah... I think if you push down on the middle rotary encoder it drops a marker at that spot. Shows you how much I use that function. To its credit, the AlphaTrack can be pretty deep if you delve into it. I know on some sequencers it actually displays running location readout on the display. Of course, my wish would be to be able to click on a mixing board channel in DP and have AlphaTrack jump to that track. LOL. Basic, huh?BobK wrote:I wouldn't be surprised - Tranzport has a button programmed for inserting markers (I think) and also ones for locating to previous and next marker. (I don't use my Tranzport any more - should probably sell it...)James Steele wrote:Hmmm... not that I use it all that much, but I think the AlphaTrack has some built in function for dropping a marker. At least I vaguely recall something like that? Maybe it's just the ability to turn a rotary encoder and it will jump forward and backward through markers.
I use DP key commands for 'previous marker' and 'next marker', and I've been doing that for so long I don't recall if they're stock commands or if I set 'em up myself. But find them very handy.
Mac Studio M1 Max, 64GB/2TB, MacOS 14.5 RC1, DP 11.31, MOTU 828es, MOTU 24Ai, MOTU MIDI Express XT, UAD-2 TB3 Satellite OCTO, Console 1 Mk2, Avid S3, NI Komplete Kontrol S88 Mk2, Red Type B, Millennia HV-3C, Warm Audio WA-2A, AudioScape 76F, Dean guitars, Marshall amps, etc., etc.!
Silly question - have you tried trashing DP's prefs file? That usually fixes inexplicable squirrely behavior for me.EMRR wrote:I can't arm one track, use the up/down keys, and get additional tracks to arm. All I get is the armed track to disarm and change to the adjacent track. I am never losing the purposeful track arming, I'm keeping those and getting random additions of the conductor track armed. I'm never getting other audio tracks accidentally armed.
Geez, I'm getting in on this kind of late, but I know just how the original poster feels.
You see, there's a pixel I hate in the MIDI tracks. It's right here:
See it? You have to look really close. It helps if you put that picture in Preview and blow it up to full-screen size. See that pixel? It's always there. I swear sometimes I am pretty sure it's sucking out the notes. Yep. Just erasing them and replacing them with wrong notes that I'm pretty sure I didn't play. I know it's that pixel, because of the way it looks at me after a take. It sucks out notes and sits there with this sulky pixelly look. It's getting even with me. What'd I ever do to it? Dang! I know I didn't do anything to it, but it's still there, changing my notes, making my vibrato come out wrong, ruining my mixes, making me sound like an amateur.
Why can't MOTU just leave that pixel out? Sheesh, MOTU tech support hasn't been any help at all. They didn't even respond to my technote. I think they secretly want to leave that pixel there.
I'll get that pixel yet! I'll turn it purple. THEN see who has the last laugh.
Stupid pixel.
________________
Stupid pixel.
________________
HEY! My conductor track took a hike! It's seen here hiking the Appalachian Trail - or so it says! It's actually hiking in Logic!
BASTARD! It even took the list editor with it. You can see it hanging from it's waist. OMG! What will become of me now? I'm doomed. Doomed!
- FMiguelez
And no wonder you've been having issues with BTD. WHAT do you think he's carrying on the backpack?
The Blues, of course!
MIDI Life Crisis wrote:The Blues, of course!
DOH!
There's that pixel. It's showing up in Fernando's posts, now!FMiguelez wrote: .
