Full Switch from Mac to PC, from VST to SX, with a 896 mk1
malhomme
Post by malhomme »
Which switching proves to be a total nightmare...
I am fairly new to this...
I wanted to take advantage of my all UAD-1 crads, while buying a new UAD-2 Duo, so I decided to let go 15 year sof Mac and go XP.
Not wanting to be lost in a too rich universe, I decided to buy a computer from a specialist (DirectResolution) and bought a i7 computer with XP home sp3, and a fair amount of twitching of MOBO and windows by these people...
I had it a few days away so what did I do: d/l the lastest drivers for my 896...
I still have my old copy of VST 32 5.1. It seems to work, but I did not get far...
But using a standalone plug in makes the motu cracks like hell like it never did with my old 1999 mac G4.
Using it with SX3 (I have a faire amount of about 400 songs to get back, so a second hand cubase SX3 was necessary to import these. Maybe later I'll upgrade to cubase 5) is a nightmare.
The MOTU just does not work at all. It will issue no sound. not even a click...
Selecting the output in cubase SX will crash cubase. In VST 5 it will not. Used in Windows, it will work but blips and cracks like I had a 90's computer.
Should I find older drivers ?
Since I am fairly new to all this (XP, MOTU drivers on XP, cubase SX) this is difficult to identify where it fails...
Any idea would be greatly regarded... I need toi be pointed in a selected number of problem I could check...
Thanks in advance
Olivier
Mark S
Re: Full Switch from Mac to PC, from VST to SX, with a 896 mk1
Post by Mark S »
Welcome to the world of IBM. (since that's where the standard started)
First difference is that in the Mac world hardware and software choices were limited and so were the things you need to concern yourself with. But your options were limited too.
Here you'll need to be specific about hardware and software you are using including: mobo, ram, Ox version, hard drive config, net config, software, sound interface,... be specific
get the picture?
Don't let it overwhelm you. most of the issues are basic configuration issues that are easily resolved
First, let's get the MOTU working. then the cubase people can deal with that one
malhomme
Post by malhomme »
Mmmm I get it.
I don't have all the details...
The MOBO is a gigabyte... know the PC was extensively tested before being shipped...(they do stress test before shipping)
It has 3 gb ram,
It has XP home edition,tweaked for audio use. Bios also has been tweaked the same way (ethernet disabled, sound card disabled, and some obscure stuff I don't even know about).
It has a Texas Instrument firewire chip
I took this for their site:
CPU: Intel Core i7 2.66GHz QUAD CORE (8 threads HT)
COOLING: 120mm CPU cooler and exhaust fan
MAINBOARD: Gigabyte X58 motherboard
RAM: 3GB DDR3 1333MHz (3x1GB) Triple channel RAM
HDD1: 320GB OS drive
HDD2: 640GB Audio drive
PSU: 650W Quiet Modular PSU
GPU: HD3450 ATI dual ouput silent cooling
OPTICAL: DVD R/RW
FIREWIRE: 2x Texas Instrument firewire ports
CASE: DARC MKII 19" Rack case with acoustic insulation
OS: Windows XP Home custom install
I have been wondering if there were driver issues ?
I am considering trying to uninstall the drivers and install the one I had with CD delivered with the 896.
To make a test....
TheRealRoach
Post by TheRealRoach »
Try following these steps:
1. Make sure you have a drive image and/or system recovery disc so that if anything goes bad you can revert back to factory configuration.
2. Disconnect MOTU hardware.
3. Uninstall MOTU drivers.
4. Reboot.
5. Delete any leftover MOTU entries from the registry (Start Menu -> Run -> type "regedit", then search for and delete all "MOTU" entries.)
6. Reboot.
7. Reinstall version 3.6.7.0 or 3.6.7.4, they should be posted somewhere on this forum.
8. Reboot.
9. Connect and turn on your motu hardware. It should automatically run "Found New Hardware..." wizard and install the drivers for the device.
Let us know what happens after that.
Mike Rocha
http://www.mikerocha.ca
Custom ADK, Quad 3.0ghz, 4gig ram, Win7 64-bit, Motu 3.6.7.3 x64 drivers
Macbook Pro 13" touchbar, High Sierra, 73220 drivers
Motu 896 x 4
malhomme
Post by malhomme »
Hello..
In the meantime, before reading this last post, I did something similar (with the exception of the regedit thing I don't know about, but this is the first time I get into windows) uninstalling everything (I mean everything, to return the computer state to its arrival state), and run again every installer (except also that I ran the lastest driver at the time)...
For a reason I don't know (and I have not made "stress test" so far), it works now properly (until I get more into Cubase).
The only issue I have is that sometimes, the 896 jump to 48 kHz (but I don't know it it is a 896 issue, a machine issue or a Cubase issue)
Anyway, I'm pretty close to running. I am still into painfully installing to restore my Mac's VST plug in folder, to prepare for a easier importing of my Cubase VST songs into SX.
I will anyway get these legacy drivers (any reason to choose old driver of latest one, by the way ?)
And thank you very much for the help and useful comments.
